Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #11
Old 19-07-17, 06:25 PM
10thDmenxn 10thDmenxn is offline
Newbie
Originally Posted by WYP View Post
I am using G.Skill Trident Z 3200MHz. G.Skill is one of the better brands in terms of Ryzen support ATM.
I have worked with TTL on most of his Ryzen reviews and G.Skill is one of the few brands that have worked flawlessly for us since launch. A lot more kits work today with mature BIOS' but G.Skill has been great from the start.
I have heard that the FlareX is better than the Trident Z. Do you know if this is true, or do you think it's bs?
  #12
Old 19-07-17, 06:26 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Originally Posted by 10thDmenxn View Post
So you believe Ceramique is better than MX-4?
Thanks to all of you for the information. I have been overseas the last 16 years, so I'm scrambling to catch back up. I appreciate the responses.
From what I read about Ceramique it is a couple of C warmer than MX-4. However, having used it for the last six years or so I have noticed that it does not dry out or become crusty like some other pastes I have used so I have just stuck with it. What's not broken, and all that.
I bought an enormous tube three years back and still have a bit left
__________________
If you don't like what I post don't read it.
  #13
Old 20-07-17, 08:41 PM
Newbie
But the consensus is that the Artic Silver is not nearly as good as the MX-4 or Ceramique?
  #14
Old 20-07-17, 08:45 PM
AlienALX's Avatar
OC3D Elite
https://www.amazon.co.uk/Arctic-Silv.../dp/B006K4VT3W
No idea, but the day I spend more than £10 on a tube of that stuff will be the day I show my arse in Tesco's window.
__________________
  #15
Old 20-07-17, 09:36 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
To be honest with you, it's most likely very to no difference at all really when it comes to thermal compound. Maybe a degree here or there... I've used MX-4 for all of my builds, rebuilds etc and it's spot on. Cheap as well, so nothing to loose really
  #16
Old 20-07-17, 09:58 PM
AlienALX's Avatar
OC3D Elite
Indeed. I really wouldn't get suckered in by expensive stuff like that. Cheap doesn't mean crap when it comes to TIM. You don't need to buy a tube of 20p grease but yeah, a sub £5 compound will do the job well enough
__________________
  #17
Old 21-07-17, 08:29 AM
Newbie
Yeah, I got some mx-4. I have completed 90% of the build, and am just waiting on the 1080ti to arrive, and the 960 EVO. Then it will be up and running. I really can't wait. While my laptop is a beast for laptops, this is the first full system I have built in almost 20 years because I've been living overseas in the islands. So it will be nice to have a really fast and powerful computer again. thanks for the answers.
  #18
Old 21-07-17, 08:34 AM
AlienALX's Avatar
OC3D Elite
Well good luck mate and I hope she all works as she should
If my CPU turns up today it will be a very big day for me too
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
