Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 23-03-21, 02:27 PM
WYP's Avatar
WYP WYP is offline
News Guru
Nintendo's upgraded Switch will reportedly feature an improved CPU, memory and screen
A 4K switch that utilises Nvidia's DLSS technology.
Read more about Nintendo's New Switch/Switch Pro console.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 23-03-21, 03:28 PM
g0ggles1994's Avatar
g0ggles1994 g0ggles1994 is offline
OC3D Elite
Not going to lie, DLSS on a Switch does seem like the right way to go as it will help make it run and look better without needing all the horsepower to do so.
If this new Switch does come, I'm pouncing on it for launch. I just wonder whether they'll update older games to run with DLSS; Breath of The Wild and Xenoblade 2 would look incredible
__________________
Ryzen 1700X @ 3.6GHz | MSI X370 Gaming Pro Carbon | Corsair H100i v2 | 16GiB Corsair Vengeance LED Blue
ASUS RoG Strix Vega64 8GiB | 2TB WD SN750 | Corsair RM850 CableMod | Phanteks Enthoo Pro M TG
  #3
Old 23-03-21, 03:51 PM
Digikid Digikid is offline
Advanced Member
I just want a good XL version made for ADULT hands.
__________________
My opinions are my own. I do NOT care what you think of them and I will post them freely. If you do not like it...tough.
  #4
Old 23-03-21, 04:57 PM
Bagpuss Bagpuss is offline
Member
DLSS is only really meant for docked play on a large 4K screen, which I suppose is very much in the minority usage amongst Switch owners.
..The fact that in mobile mode, its still coming with only a 720p screen will mean the boosted hardware should be capable of quite a lot more than what it currently is.
  #5
Old 23-03-21, 05:15 PM
tgrech tgrech is offline
OC3D Elite
DLSS could certainly help the Switch in handheld mode too you'd think, as it allows fancier settings and/or lower battery use and/or pegged 60FPS, 480p DLSS to 720p would probably look about as good as native but with significantly lower load (Less than half the number of pixels of 720p).
  #6
Old 23-03-21, 06:27 PM
looz's Avatar
looz looz is offline
OC3D Elite
Well if the device is DLSS capable, developers can dictate how to use the tech for their use case. Maybe more aggressive presets could be enabled on demand as a battery life extender.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #7
Old 23-03-21, 07:25 PM
OC3D Elite
Agreed with this. Some games could easily go this route while others can make themselves look better without having any impact on battery life. Xenoblade 2 for example can have resolution drops below 480p in certain parts in handheld mode; DLSS could make it play at 720p. Docked, it could easily run at native 1080p.
DLSS can do a lot of good for the Switch. At least all they'll need to do is create a DLSS profile for handheld, docked 1080p, and docked 4K
__________________
  #8
Old 24-03-21, 01:07 AM
AMD Enthusiast
It would be interesting to see DLSS impact on battery life. It remains to be seen how good DLSS can upscale low resolutions like 720p.
Sounds like a big upgrade.
  #9
Old 24-03-21, 10:32 AM
WYP's Avatar
WYP WYP is offline
News Guru
I'm guessing that it won't be used in handheld mode, or it will be used for "SuperSampling" at 720p. Hard to know.
__________________
Twitter - @WYP_PC
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
