Go Back   OC3D Forums > [OC3D] Customer Care Forums > Aquatuning Customer Care
Thread Tools Display Modes
  #21
Old 19-05-13, 01:49 PM
vorticalbox's Avatar
vorticalbox vorticalbox is offline
OC3D Elite
Originally Posted by tinytomlogan View Post
Be patient
something you're not telling us Guvnor ?
__________________
Photo Blog
  #22
Old 19-05-13, 04:42 PM
airdeano airdeano is offline
OC3D Elite
Originally Posted by SuB View Post
I'm behind the 140mm fan thing. I need to replace all mine cuz they're rubbish, but the alternatives aren't worth trying at £10 a pop... (i need 8).
A Corsair SP140 or similar from Noctua would seriously get my attention...
Be patient
said the master to grasshopper
  #23
Old 20-05-13, 05:46 PM
Aquatuning's Avatar
Aquatuning Aquatuning is offline
Member
Phobya will have some 140mm eloops soon I expect
  #24
Old 20-05-13, 06:26 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Awesome! Provided you can take off the rotor as with the 120 version they don't even need
to be the right color; I could probably dye them (red/black wouldn't really fit the build for which
they would be used, I would need something more black/dark grey or similar).
Either way, this is great news for me.
  #25
Old 20-05-13, 07:38 PM
alienware alienware is offline
Banned
Send a message via MSN to alienware
Forgive me i havent had a chance to properly read through all the posts (I will come back to them) but i can answer this one quickly
http://www.aquatuning.co.uk/product_...U---Black.html
Fully upgrade able - full copper rad. or for the full "custom" experience:
http://www.aquatuning.co.uk/product_...-XT---kit.html
both of these will spank closed loop coolers
Hey thanks for the reply ! Yeah I saw the CM one recently it looks pretty B.A.
  #26
Old 21-05-13, 04:54 PM
Aquatuning's Avatar
Member
Black ones will also be available
  #27
Old 12-03-14, 02:28 PM
tonschk tonschk is offline
Newbie
Airen Extreme `140mm Red fan
Hello there, please can Aquatuning sell this Airen Extreme 140mm Red fan?, at the moment Aquatuning don't have in stock a fan with this design, 7 red blades with black frame, thank you
http://www.airentec.com/en/catalog/redwings-extreme-140
__________________
http://www.ae911truth.org/
  #28
Old 12-03-14, 05:48 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
I'd like two products brought to market...
1) Corsair SP120 quiet edition LED fans.
2) A dual bay EK Spin non-CSQ reservoir designed to be mounted on its side in a Carbide 540 Air with the fill port on one side instead of the top.
__________________
  #29
Old 12-03-14, 06:01 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Green LED fans optimized for airflow that also look as good as the SP/AF series considering Corsair did every colour but green for some unknown reason
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #30
Old 13-03-14, 08:29 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
I thought they did green but they didn't hit Europe or some other BS ?
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
