Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #11
Old 16-01-20, 04:40 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Originally Posted by notcool View Post
I won't be upgrading for a while yet, I have a good AV so Windows Defender updates are irrelevant to me.
Antivirus will not protect you from severe backdoors or vulnerabilities found since the final round of security update, new definitions and threat detections for defender are one thing, but any newly discovered flaw or security issue that could give hackers access to your system will not be patched, hence av software being less then ideal for this.
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
  #12
Old 16-01-20, 06:04 PM
AMD Enthusiast
If you have a dedicated firewall and an insanely locked down network process you'd be fine remotely, but doesn't mean you're invulnerable.
__________________
I am Iron Man.
  #13
Old 17-01-20, 05:10 AM
Thanos's Avatar
Thanos Thanos is offline
Newbie
Still using Vista here now and again as well as W7, nothing worth stealing AFAIK and restoring a backup should fix any unpleasantness. Weird how Vista still keeps notifying me there are updates available.
Not spending ~$130 each for more W10 OS's while they work fine as they are for my needs. So not missed for now but eventually they will become obsolete.
  #14
Old 17-01-20, 05:27 AM
AMD Enthusiast
dude. It's freaking free what are you on about
__________________
I am Iron Man.
  #15
Old 17-01-20, 10:30 AM
tgrech tgrech is offline
OC3D Elite
Yeah you can use a legit Windows 10 install with no license with fewer annoying notifications than those update messages. If you're a student you can usually get a free copy or a hefty discount, or third party keys can be found in the region of £10-£30.
If you're only using it for a gaming PC that never does anything else and mostly plays older games then I guess you can do whatever but if you're actually doing anything involving any kinds of payments or sensitive details or work you should probably stop using an OS that's almost old enough to vote.
  #16
Old 17-01-20, 08:47 PM
looz's Avatar
looz looz is offline
OC3D Elite
If you don't want W10, going Linux is the better option than sticking to abandonware. Most Dx11 titles work well on penguinland, though anticheats and DRM don't often work.
Outside gaming it's a mixed story as well, if you need MS office or Adobe suite, it's not the best platform. But tools for listening music, organising music libraty and amateur photography are IMO better on Linux, especially compared to free alternatives on Windows.
Important bit is still receiving security updates and also stuff like latest codecs and so forth.
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #17
Old 17-01-20, 09:46 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I'll be honest I have not used it in several years.
I packed it in when Core Parking was an issue in 7 and moved onto 8. So that would have been about when I had my FX 8320 to give you a rough idea.
Not looked back since. I was one of the few who liked Windows 8 with the Start button.
__________________
  #18
Old 20-01-20, 09:15 AM
notcool notcool is offline
Advanced Member
I take your point, however, I have everything worthwhile backed up not connected to my pc or network so even if I got ransomwared it wouldn't really matter.
  #19
Old 20-01-20, 03:14 PM
g0ggles1994's Avatar
g0ggles1994 g0ggles1994 is offline
OC3D Elite
You me both mate. Problem was that 8 was too much of a change for people to handle; for all the UI complaints, 8 was very stable under the hood which is what matters in an OS
__________________
Ryzen 1700X @ 3.6GHz | MSI X370 Gaming Pro Carbon | Corsair H100i v2 | 16GiB Corsair Vengeance LED Blue
ASUS RoG Strix Vega64 8GiB | 240GB Corsair Neutron GTX | 1TB HGST | Corsair RM850 CableMod | Phanteks Enthoo Pro M TG
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
