Thread Tools Display Modes
  #211
Old 20-11-18, 07:06 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Originally Posted by Warchild View Post
hmm. Careful you dont go OTT on RGB. If the light bleeds inside the case it will ruin all the contours and design. All you will see is a case washed out in a certain colour.
It's all controllable. I can switch the whole lot off if I want to I have separated it into zones, pretty much the same way the Alienware software does it, so I can turn off the inside but leave the outside and vice versa. Ram is on a separate channel to the halos, flow meter and LED strips. So yeah, each zone can be completely disabled.
Which after about three weeks is probably how it will end up lmao.
Ed. Don't quote me on this but I *think* you can dim the lights with the Farbwerk? I will find out soon enough I know you can on the Alienware lights by adding black.
__________________
  #212
Old 20-11-18, 07:40 PM
Bartacus Bartacus is offline
OC3D Elite
You can do LOTS with the Farbwerk. Dimming is the tip of the iceberg.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #213
Old 20-11-18, 07:42 PM
AlienALX's Avatar
OC3D Elite
Sweet, 'cause those ram sticks are awful bright lol.
That's basically why I tried to create the inside as neutral and reflective as possible. I can literally choose any colour I want and have a different rig every day that way. I don't like committing to one colour tbh, it's so 2008.
__________________
  #214
Old 20-11-18, 11:45 PM
AlienALX's Avatar
OC3D Elite
Got some spare time at last, I wanted to say a few words
First of all the bloopers which I thought were kinda funny!
That lovely pump cover I made didn't quite go as intended. It barely fits with a wedgie and the alien badge is not even visible lol. I will address that soon. Bad miscalculation though
Next up, fan extensions. I bought 6 on Amazon without checking the length. Turns out they are 150mm, so pretty useless lol. I have since ordered three more lots from ocuk, but each time my maths was crap and so I've ordered a fourth. I apologise profusely for this, as it must be annoying.
I was getting a smear on the floor screen from where it got warm and was pressing against the 3mm clear Plex layer. This has now been rectified.
What I wanted to say more than anything though was a huge thanks to all of you guys here (most namely Warchild, Cenedd and Bart) for their help,advice,and suggestions.
One thing I've always liked about myself is that I can sense the constructive part of constructive criticism and see it as advice and use it positively whilst never EVER thinking that I am perfect or beyond blatantly good advice.
My log photos are never great, I talk too much but I listen,too.
So I doff my cap to you guys. I can't do this s**t without you and this place has been the rock for me and the build.
__________________
  #215
Old 21-11-18, 08:28 AM
AlienALX's Avatar
OC3D Elite
Another thank you to Scuba Steve, who kindly sent me some RGB cables. D'you know what's weird? I used the last one to connect up the last RGB run.
__________________
  #216
Old 21-11-18, 12:09 PM
AlienALX's Avatar
OC3D Elite
Daylight ! oh how I have missed thee.
Fitted the GPU into the riser, fitted the stop plugs and uh oh we have a problem. Can you see it?
I wouldn't even mind if they were actually the same bloody size *waves fist*
Total bust that was. I guess I will have to resort back to the sodding hex wrench bolts
__________________
  #217
Old 21-11-18, 01:05 PM
Warchild Warchild is offline
OC3D Elite
I'd be more annoyed that the logo is differently sized.
  #218
Old 21-11-18, 01:10 PM
AlienALX's Avatar
OC3D Elite
Yup could probably have pulled it off then *sigh*. Mind you, it has made me realise how much I don't want a logo on that part, so I've ordered two of these.
And will use the premium plugs to fill the holes in the res etc.
__________________
  #219
Old 21-11-18, 01:13 PM
OC3D Elite
Yep and this is why I strongly recommend barrow. I don't really like the BP plugs you have either, prefer their newer ones with the knurled grip.
  #220
Old 21-11-18, 01:16 PM
AlienALX's Avatar
OC3D Elite
I have one of those in chrome (look in the back of the GPU ports) but I am terrified about paying £7 odd and getting a different logo 'cause they were trying to save on ink lol.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
