Thread Tools Display Modes
  #1
Old 17-03-11, 05:55 PM
merrymustu merrymustu is offline
Member
Send a message via Yahoo to merrymustu
My $1700 Gaming Rig build...
Gigabyte GA-P67A-UD7 (gives lots of headroom for future upgrades including 3way SLI/Crossfire as well as easy overclocking with 24 phase power)
Intel Core i7-2600K Sandybridge
Single EVGA GTX 570 ( will go for a 2/3 way SLI in future)
Corsair HX 1200W power supply (for future graphic card upgrades)
Corsair Vengeance 2 X 4GB DDR3 1600MHz
Corsair Performance 3 series 60GB SSD
Samsung Spinpoint 7200RPM 1TB harddrive
Noctua NH-D14 cooler
Antec 900 case
Guys please comment...
  #2
Old 17-03-11, 06:02 PM
KaraMurat's Avatar
KaraMurat KaraMurat is offline
Advanced Member
Get a bigger case such as a BitFenix Colossus or NZXT Phantom rather than the Antec 900 other than that, seems all good. Actually an SSD might be a good idea too.
  #3
Old 17-03-11, 06:29 PM
Firat's Avatar
Firat Firat is offline
OC3D Elite
I don't think that ram you have chosen will fit under the NH-D14 check out mushkin (ridgeback 6-8-6-24)
__________________
The brave may not live for long but the cautious never live at all.
If it takes you longer to do something than to think it up, then you need to plan again.
  #4
Old 17-03-11, 06:59 PM
sg12004's Avatar
sg12004 sg12004 is offline
OC3D Elite
ya that looks like it will be a good system but just get a full tower case
__________________
MSI Z97 Gaming 7 / Intel I7 4790K 4GHZ / AMD Radeon R9 290 4GB GDDR5 / 16GB DDR3 Ram 2133MHZ / 2x 256GB SSD Raid 0 / 500GB 7200 HDD / Killer E2200 Lan / Corsair RM 750 gold / Corsair H105 / NZXT 440 /
  #5
Old 17-03-11, 07:31 PM
ruthless_villain's Avatar
ruthless_villain ruthless_villain is offline
OC3D Elite
maybe 1kw instead of 1.2kw
yeah reconsider the memory.
2500k instead of 2600k and money could be spent on a 580 instead??
just a thought
__________________
  #6
Old 18-03-11, 05:05 AM
Member
thanks guys for the useful replies, i am really now thinking of buying some other ram, maybe the kingston genesis...I was a little bit puzzled on your opinions about the case---Won't an antec 900 do the job????
  #7
Old 18-03-11, 06:39 AM
AMDFTW AMDFTW is offline
OC3D Elite
that RAM wont fit under the DH14 mate
there are alot more better cases to offer thatn the antec 900 depending on your budget look at the advanced 2 and anything (in reason) above that
  #8
Old 18-03-11, 08:24 AM
kilobravo kilobravo is offline
OC3D Elite
Send a message via MSN to kilobravo
The 900 is only 200mm wide,the 902 v3 is 220mm and should fit the noctua better.
And you need other rams to fit under the under the cooler.
But look for a better case than the 900.
Other specs look good
Why not a lian li pc a70f case.
__________________
  #9
Old 18-03-11, 02:45 PM
DragonPC DragonPC is offline
Member
the antec 900 sux if not spend some extra bucks for the 902
  #10
Old 08-04-11, 10:56 PM
yuyo12 yuyo12 is offline
Newbie
i think you should get a 120 gb ssd minimum. 60 won`t be enough for win7 and some programmes and games
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
