Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 28-10-19, 05:04 PM
tinytomlogan's Avatar
The Guvnor
1.5v CPU voltage is more than likely your problem fella
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #12
Old 28-10-19, 06:10 PM
TuN TuN is offline
Newbie
Ok I have decided to do a bios reset before I'm gonna remove the Kraken and put the Wraith on. So I've done that and re-ran the Cinebench R20 and IBT, and here are the results:
Not sure what I've activated ( and forgot about it ), but I know I've had might be Precision Boost Overdrive - Enhanced Mode 4. I was just sure that I've put it back as it was, apparently not. 25 degrees difference in OCCT. Woah.
So I can start to fiddle around now. Thanks for the help, everyone.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
