Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #1
Old 30-09-14, 04:49 PM
jaspervandervalk's Avatar
jaspervandervalk jaspervandervalk is offline
Member
Asus Maximus VII Gene || Ethernet issues ||
Hi there peeps.
I just finished my build today and one of the components is an Asus Maximus VII Gene, everything is working fine but I am having issues with ethernet. I just cannot connect to the internet...
I am not sure if this is because I haven't installed drivers, I have broken something or I am just being an idiot. Anyway the ethernet cable I am using is fine, I used it this morning and can still use it fine on other devices.
There is an orange flashing light on the Mobo next to the ethernet port but I am not getting any internet. If anyone could help out it would be much appreciated! Thanks in advance.
Regards, Jasper.
  #2
Old 30-09-14, 05:27 PM
paulstung's Avatar
paulstung paulstung is offline
OC3D Elite
You need to install the drivers mate, you won't get anything until you do.
  #3
Old 30-09-14, 05:55 PM
Member
Thanks for your reply. Yeah I did think this, okay well ile have to download them to a USB and then install them that way because I have no network card or disk drive LOL!
Regards, Jasper.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
