Thread Tools Display Modes
  #31
Old 15-02-20, 10:15 PM
WYP's Avatar
WYP WYP is offline
News Guru
UPDATE TIME -
BIGTREETECH SKR Mini E3 - Quality Difference
This has been a long while coming, but here is an example of what upgrading the Ender 3 with a BIGTREETECH SKY Mini E3 can do. While both models are accurate, you should be able to see the artefacts that the new motherboard can fix.
Add this to the noise difference, and the upgrade is more than worth it for the £30 it costs.
Before:
After:
Upgrade that Creality Made over older Ender 3 models
I forgot to note that Creality has upgraded its Ender 3 models to add the metallic guide into the extruder assembly. Before now the filament fed into plastic, which wore out over time.
Now, this metallic insert should increase the durability of Creality's stock extruder. Nice upgrade.
Misc Upgrades
For starters, I printed this Imperial Extruder knob so I could more easily feed or remove filament into and out of the printer. A must print for anyone who owns a 3D printer like this.
This is how my Filament is connected to the system. I preferred that my Ender 3 was wider than it was tall, and this way filament feeds into the printer in a more direct manner.
Another thing I printed was a set of drawers, which I use to house all of the tools that came with the printer, as well as a few extra parts. Very handy.
New Upgrades
Dual Lead Screw Setup
This upgrade is semi-custom. It takes inspiration from the work of ProperPrinting on Thingiverse, but also contains parts from other makers as I didn't want to compromise the maximum Z-height of my Ender 3.
Some of these models needed a bit of TLC to work, but I hope to make some of my own models so that I can release my own guide for this. I have a few cuts in my fingers to attest to how much material needed to be removed from some of these pieces.
I would have liked to model all the parts myself, but I don't have the time ATM. Solidworks is the software that I know, but you don't use that software outside of big businesses. I'll need to learn something new, perhaps Blender.
Inspiration Links -
https://www.thingiverse.com/thing:3746653 (primary source)(models don't support anti-backlash lead screw nuts)
https://www.thingiverse.com/thing:1061769 (model source)
https://www.thingiverse.com/thing:3080912 (material removal required to fit my 608ZZ bearings)
Securing the top of the Ender 3's original lead screw. Do the same thing at the other side with the new Lead screw.
Adding the new Z-axis bracket to the Ender 3.
It takes a bit of footering, but there is enough space to get the timing belt on to connect both lead screws.
With some calibration, you can square things up and remove the sag of the X-axis on the Ender 3 and make bed levelling a lot less frequent.
You can now lift the Ender 3 using the X-axis bar and get no sag. which is something that you couldn't risk before. I still don't recommend doing that, but the extra rigidity speaks for itself.
The only downside of this mod is that the PSU box now has no proper place to stand.
Next Mod
Right, now the PSU looks like this.I need to reconnect the PSU to the Ender 3's frame and find a new way to reduce the noise of the Ender 3's fan.
I have installed a baffler to lower the noise levels, but it only offers limited help.I believe that the fan in there operates on 12V, so I could replace it with a PC fan, perhaps this spare 120mm fan I have. (or I could go for one of those Grey Noctuas... decisions decisions)
This fan is the loudest in the 3D printer right now. It turns on for a while and then off for a while, very annoying...
Model Source for PSU Baffler
https://www.thingiverse.com/thing:3344508
What's next?
Aside from the PSU fan mod, I really need to learn a new 3D modelling program. This will allow me to design my own parts. Hopefully I will soon have time to dedicate to learning something.
__________________
_______________________________
Twitter - @WYP_PC
  #32
Old 16-02-20, 06:07 PM
Bartacus Bartacus is offline
OC3D Elite
Have you considered a new PSU entirely? I'm reading that a lot of the stock PSUs are very cheaply made, and replacing them with Meanwell PSUs is commonplace.
Great job on the mods!! That Bigtree made a HUGE difference!!
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #33
Old 16-02-20, 06:38 PM
WYP's Avatar
WYP WYP is offline
News Guru
I own the Ender 3 Pro, which ships with a Meanwell PSU in its stock configuration alongside some thicker aluminium extrusions along the Y-axis.
While the Meanwell PSU is better than the basic Ender 3's PSU, it is still loud when the fans are on. I'm sure I could upgrade to a different power supply entirely, but I'm sure I can print a bracket which will allow me to use a PC fan for cooling. I don't want to spend much more money on this ATM.
__________________
Twitter - @WYP_PC
  #34
Old 16-02-20, 06:47 PM
OC3D Elite
Cool, I didn't realize the Pro ships with a Meanwell. The variations between the models is still a bit confusing!
__________________
  #35
Old 17-02-20, 01:21 PM
tgrech tgrech is offline
OC3D Elite
If you want a super easy and quick to use tool for upgrade/ease of use parts then maybe try Tinkercad, while it's missing a lot of advanced features and wouldn't be useful for detailed models, it's more than usable for designing things like cases and mechanical parts, is a free online toolset and can export to .stl for doing finishing touches in Solidworks if need be.
  #36
Old 17-02-20, 02:53 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Fusion 360 is also free for personal home use. I've used it to make small modifications to .stl files.
https://knowledge.autodesk.com/suppo...usion-360.html
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #37
Old 22-02-20, 09:48 PM
WYP's Avatar
WYP WYP is offline
News Guru
Thanks for the tips guys. Just downloaded Fusion 360. Seems similar enough to Solidworks for me to get started quickly.
I haven't created anything complex yet, but it took a few minutes to move from basic sketches to a 3D model.
__________________
Twitter - @WYP_PC
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
