More of this mornings progress...
That's the rear extract 140mm Xilence CF2 mounted
I've used anti vibration mounts to eliminate noise as much as possible
Installed the Power Supply Unit
I'm using a Seasonic X-Series 650W Full Modular Power Supply
And pre installed the dual 8-Pin EPS12V Extensions
Plus the 24-Pin ATX Extension
These are just some eye candy shots
