Go Back   OC3D Forums > [OC3D] Customer Care Forums > MSI UK Forum
Thread Tools Display Modes
  #11
Old 09-01-17, 09:28 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
From what I recall using two ribbons was not the same as using a hard 3 way bridge. Or a hard double bridge. Apparently the traces in hard bridges are heftier than the flexible ones and thus can handle more bandwidth.
There was a big debate about it on OCUK and Ben from EVGA talked it through, confessing that they were pretty much just hard bridges with double fingers. However, hard bridges are better than soft ones apparently, for the reasons above.
__________________
"Those really high 20 series prices are just place holders"
  #12
Old 09-01-17, 09:38 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
That's literally all it is, the hard ones are slightly better made, and the soldering is a little better, but there's not much different in the way of bandwidth in real life at all. The bandwidth is set by the card using it, and HB bridges are literally just two single bridges, stuck together. The Xrays I posted not long ago proved it
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #13
Old 09-01-17, 09:52 PM
othertomperson othertomperson is offline
Newbie
Yes and no. Judging from the X-rays of the SLI bridges the hard bridges' traces aren't "heftier", they have kinks in them to ensure that they are all the exact same length. This is what allows the frequency increase from 450 MHz to 600 MHz. The new SLI bridge is not only doubling the bandwidth by running two in parallel (what I'm currently doing), but also by increasing the frequency of the signal passed between them too.
Let's be real, though, the difference is marginal and I'm mainly wanting this for aesthetic.
  #14
Old 09-01-17, 09:57 PM
AlienALX's Avatar
OC3D Elite
Yeah they kinda put Ben on the spot so he really couldn't lie about it. I've never used the soft bridges myself. Used to get corruption and so on, they are really finicky !
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
