Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
Thread Tools Display Modes
  #1
Old 16-04-16, 10:35 AM
podgeabald podgeabald is offline
Newbie
Send a message via Skype™ to podgeabald
CPU temp Software
I know this is most probably on here somewhere but I'm a bit of a lazy git today and can't be bothered looking.
What is the best free software out there today to test CPU temps as accurately as possible
I wish to try and do a temp comparison with my new Corsair H55 closed loop system with my 8 fan passive setup. x5 120mm, R9 380 built in fan and x2 80mm in side panels
My passive setup usually idles at 26 Degrees and under 100% load max's at 41 Degrees
thats with using Aida64 Extreme but i can't trust the temps as after the latest update my CPU is being recognised as a AMD x4 Athlon 3.2ghz 955 instead of a AMD x4 Phenom 3.2Ghz Black 955. so due to the little problem I no longer trust the software.
Any help would be much appreciated.
  #2
Old 16-04-16, 10:42 AM
Kushiro Kushiro is offline
OC3D Elite
Core temp HWinfo etc pretty much all just get the temp from the sensor. Both are fine.
__________________
i7 5930k 4.7Ghz ~1.34v - Asus X99 Deluxe - G.Skill 32GB 2800mhz 4x8GB - NZXT Switch 810 White Edition - 3x EVGA Geforce GTX 980Ti - 2x Samsung 850 2TB - Corsair AX1500i
Watercooling - custom
  #3
Old 16-04-16, 10:45 AM
Doomslayer Doomslayer is offline
OC3D Elite
Real Temp works but it's only does Temp i think maybe good to run both at the same time.
  #4
Old 16-04-16, 10:48 AM
tinytomlogan's Avatar
The Guvnor
I always use HWmonitor (same people as CPUZ)
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #5
Old 16-04-16, 12:45 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
What the boss man said.
  #6
Old 16-04-16, 02:02 PM
Newbie
thanks all will use and compare and let you all know the diffrence
  #7
Old 16-04-16, 02:10 PM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
MSI Afterburner is ok if you have it installed for GPU overclocking.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #8
Old 16-04-16, 02:23 PM
Newbie
My results
After running a 10 minute stress test with the before/after.
Previous results with Aida64 Extreme Passive Cooling
  • Idle settled at 26 Degrees.
  • Max load Settled at 41 Degrees.
New Results with HWMonitor Closed Loop Corsair H55
  • Idle settled at 24 Degrees.
  • Max load settled at 34 Degrees.
the Idle temp as you can see there is not much difference only 2 Degrees but under max load 7 Degrees difference, Which I think is a big difference.
  #9
Old 16-04-16, 02:40 PM
The Guvnor
If your bios is upto date then hwmonitor is 99.99999% of the time the one to trust.
__________________
  #10
Old 16-04-16, 02:43 PM
Newbie
thanks as far as I know my bios is up to date the last update release was the beginning of last year.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
