Go Back   OC3D Forums > [OC3D] Customer Care Forums > Aquatuning Customer Care
Thread Tools Display Modes
  #1
Old 18-02-16, 12:26 PM
Aquatuning's Avatar
Aquatuning Aquatuning is offline
Member
New: Alphacool borosilicate glass hardtubes
Two videos with the new glass hardtubes from Alphacool.
  #2
Old 18-02-16, 12:47 PM
SparkleDJackson's Avatar
SparkleDJackson SparkleDJackson is offline
OC3D Elite
dont like the idea of a dremel to cut it but everything else i think sounds fantastic.
__________________
6900k, Evga GTX 780 SC 6GB SLI watercooled w/backplates
64GB Corsair Dominator Platinum 3200, Rampage V Edition 10
Corsair 900D.
  #3
Old 18-02-16, 12:48 PM
Aquatuning's Avatar
Member
It`s glass... very hard glass, so there is no other option than a dremel :-/ But it is easy to cut:
  #4
Old 18-02-16, 12:53 PM
OC3D Elite
i may have to work on my dremel skillz before i tackle this hahaha. and buy a diamond disk aswell. is it just me or to the fibre disks like to jump. what sort of finish does the end get after grinding the face after the cutting. does it leave it with a smooth satin finish or does it leave it borderline polished.
__________________
Corsair 900D.
  #5
Old 18-02-16, 01:33 PM
Aquatuning's Avatar
Member
You are talking about the head site of the cut? It has a satin finish but its not so easy to have a very nice finish. Our problem was, the dremel is too fast on the slowest level. I think, if you have a dremel with very low rpm you will get a perfect satain finish. If the rpm of the dremel is too fast, you will have a very bad finish wit small splinter. But, if the glass is in the fitting, you will see nothing.
  #6
Old 19-02-16, 01:15 PM
The_Governour's Avatar
The_Governour The_Governour is offline
OC3D Crew
how would the bends be made? or do you have some fittings for those?
  #7
Old 19-02-16, 01:27 PM
Aquatuning's Avatar
Member
We are selling 90° versions ;-)
  #8
Old 19-02-16, 04:34 PM
OC3D Crew
So in other words then you would have to buy a 90* piece every time you need a bend? I am only asking as I am interested in using it depending on the price. What are the current prices in Euros for the 90* bends?
  #9
Old 23-02-16, 07:26 AM
Aquatuning's Avatar
Member
Yes, you need to buy a 90° piece if you need a bend. Sure you can try to bend it by yourselfe, but than you need around 1200°C ;-)
You can see all prices here: http://www.aquatuning.de/search?sSearch=borosilikat
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
