Go Back   OC3D Forums > [OC3D] Customer Care Forums > Time To Live Customs
Thread Tools Display Modes
  #11
Old 19-08-15, 02:49 PM
kup's Avatar
kup kup is offline
OC3D Elite
Originally Posted by tinytomlogan View Post
Its really not needed tbh, any paint is fine. Motherboards dont create enough heat to warrant high temp paint.
Ive always used normal paints or Humbrol if I was in a rush
Cheers, guvnor!
__________________
.: Intel i7 4790K @ 4.5GHz :.
.: 32GB Corsair Red Vengence DDR3 @ 2400MHz :.
.: Gigabyte Aorus GTX 1080 Ti Extreme :.
.: 1x 512GB Crucial MX100 (OS Drive) :.
.: 4x 512GB Crucial MX100 Raid/0 @ 2GB/s (Game Drive) :.
.: Corsair H105 :.
.: Fractal Design XL R2 :.
  #12
Old 19-08-15, 02:51 PM
tinytomlogan's Avatar
The Guvnor
Originally Posted by kup View Post
Cheers, guvnor!
Just dont put it on too thick matey and give it a good chance to dry.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #13
Old 19-08-15, 03:09 PM
Warchild Warchild is offline
OC3D Elite
Humbrol paints are the best to use and even more so if using any spray gun. They won't crack.
My neighbour from a few years back used them to paint his brake calipers and damn, he did a good job (yellow and black hazard scheme)
  #14
Old 20-08-15, 08:13 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
Stick with enamels and you should be fine. (As Tom said, Humbrol should be fine). If you're brave, try thinning and applying with an airbrush, the finish will be much, much nicer.
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #15
Old 20-08-15, 05:29 PM
B NEGATIVE's Avatar
B NEGATIVE B NEGATIVE is offline
OC3D Elite
This.
Avoid synthetics tho.
In my world,we 2k that and call it a day........
__________________
  #16
Old 21-08-15, 12:41 AM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
I painted the heatsinks on my Gigabyte X79 UD3 with flat white. Came out really nice too
Not had any peeling or cracking either.
__________________
  #17
Old 30-08-15, 09:09 PM
sfelock's Avatar
sfelock sfelock is offline
Advanced Member
Originally Posted by Wraithguard View Post
You could always try plasti dip, avoid radiator specific paints they are designed to retain heat.
FYI I wouldn't use citadel paints from games workshop, while they are nice colour wise they don't stand up to high temps, it flakes and peels over time.
My experience with plasti-dip is this: It is not good for putting on things that get hot or need to be cooled. It dries to a very rubber like consistency and definitely does not allow for adequate cooling. I would honestly just use an enamel based paint. Nothing in your pc will get hot enough to bubble it and it goes on thin enough not to effect cooling much, IMO.
__________________
Rescue 1 Build Log
Specs:
AsRock Z97 PRO4, Intel 4690k, Corsair H60 AIO, Vengenace Pro 1866mHz 2x8GB, Samsung 840 EVO 250GB, 2x XFX R7 370 in Xfire, Fractal Edison 750M, Fractal Define S, Fractal Venturi HP-12 fans
  #18
Old 28-10-15, 04:22 PM
FirstPersonShooter FirstPersonShooter is offline
Newbie
Originally Posted by RickPlaysWarr View Post
there is a line of paints for painting Barbecue grill parts
Why on earth would anyone want to paint Barbecue grill parts?
  #19
Old 28-10-15, 06:01 PM
B NEGATIVE's Avatar
OC3D Elite
It stops the terribad rusting.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
