Thread Tools Display Modes
  #1
Old 16-02-17, 07:53 PM
NoobCase NoobCase is offline
Member
MonoChromatico 3.0 - Modded Praxis Wet Bench [PICTURE HEAVY)
WARNING - PICTURE HEAVY!
So this is not a continuous build log but rather most of my build crammed in one, as I've been too busy to be posting all steps individually or even taking pictures of all of it. But I'd like to share my build and the process nevertheless.
As with my previous builds I have reused most of the components and only added a new case (the primochill praxis wet bench) and a few bits and bobs needed to make it into a dual loop system.
Originally I had my eyes on the Open bench table but I wanted the base tray to be angled to better show of the hardware which the Open Bench Table wouldn't do unless I did some significant mods to it (most likely out of my skill level anyways) and bought a SFF PSU. Instead I've used the PrimoChill Praxis Wet Bench and ghetto modded and additional 360 rad to the front of it. If anyone from praxis is watching... there is plenty of room for you guys to perhaps add it to the middle tray. But instead of boring you lets get on with the pictures.
First things first... draining the old system
Building the new case
I did a lot of test fitting an measuring.. tedious task but important ones.
Another "mod" I did to the case was bolting a 2.5 HDD cage from a Corsair Air 240 next to the PSU. Saved me the trouble of getting more custom sleeved cables and makes access to the drivers a lot easier. After the front rad has been mounted access to anything on the bottom and was not easy.
Also found a spot for my Aquareo5 LT fan controller. Turns out the somebody tailor made the distance betweenthe cutouts above where the PSU will sit perfect. Couple of washers and MB screws and voila!
Front rad Ghetto Mounted:
It is by no means pretty - but it is on solid and doesn't botch
More pics of fitting the pump/res unti and pass throughs
Repainted a rad black again after I painted it white for a previous build
Redid my radbox as I had extra fittings available this time
Before
After
Flushing the ZMT tubing from EK.. Forgot that the very first time I used it... required me to take everything apart to clean all blocks and tubes... won't forget that again...
Ready for final assembly
Bleeding
Final shots
Ended up being by far the most extensive modding I've been doing to a case.. well if I can call drilling holes modding...
Hope you guys enjoyed it.. I know I did
A few more random shots here:
http://imgur.com/a/0fEUA
  #2
Old 16-02-17, 08:55 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
That is a very nice build!
__________________
  #3
Old 16-02-17, 09:13 PM
Member
Thank you Davva2004!
  #4
Old 19-02-17, 11:40 AM
Blade Runner's Avatar
Blade Runner Blade Runner is offline
Advanced Member
Very clean build.
  #5
Old 19-02-17, 11:12 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Nice clean build well done
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #6
Old 20-02-17, 01:45 PM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
Do you have an original build log for that HEX GEAR R40? I love that case.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #7
Old 20-02-17, 08:59 PM
Member
Originally Posted by Blade Runner View Post
Very clean build.
Thank you! Always aim for a clean look
Course I do. This build log was not updated with the radbox addition I did to it.
https://forum.overclock3d.net/showth...t=74256&page=1
And here is the first version of MonoChromatico
https://forum.overclock3d.net/showthread.php?t=72193
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
