Thread Tools Display Modes
  #1
Old 25-01-17, 03:52 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
A Wet Wraith
So after my little video receiving the Fractal Define C and the Alpha Cool Eisbear & Eiswolf in a push (drop kick) to get me to go custom loop it is time to start formulating the direction of this nerve racking build and finally dip my toe into the world of watercooling.
So for those that missed the video.
Anyway after a trial run with the Define C I discovered that it was not going to be possible to fit the 240mm rad and 2 fans in the roof, this in part because the Asus Z97 Pro-Gamer has slightly offset Dimm slots and the Dominator Platinums are just too damn tall which is a shame as I adore the Domi Plats.
So after many long conversations and milling ideas in figuring this out a solution was reached, which meant raiding TTLs personal stash and sadly for him means he lost the much beloved Asus Z97 Mark S.. that's right I shall now be using the Sabranco in the build. A massive thanks again to Tom and I shall smother her with tenderness, but this then throws up a new problem.. theme!? A predominantly black build with a white motherboard, that isn't going to fly.
Solution. we go Ying Yang with this while still keeping a Sabranco camo style, the CPU/GPU block and back plate will be getting some white covering with a splash of urban camo vinyl. Same goes for the Define C PSU cover and just for good measure finish her off with some white fans.
The loop order will remain the same as TTL created in the recent Define C watercooling video, the only difference being is that I'll be running clear tube with Mayems X1 Clear coolant.
So there we have it, I'm just waiting on a couple of little bits to arrive namely the X1 and a new ratchet hose cutter then this show can begin. Photos coming soon
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #2
Old 25-01-17, 04:01 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Nice mate looking forward to the photos and updates
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #3
Old 25-01-17, 04:56 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
damn your lucky fella like the idea of yin yang and going clear is probably a good option cos you can always add dye if not keen on the clear once its up n running.
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #4
Old 25-01-17, 05:27 PM
AMD Enthusiast
Needless to say I was very very hesitant to click on this thread. Wet Wraith. Just so many bad possibilities there
You doing anything super special to this build?
  #5
Old 25-01-17, 05:40 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Just the opposite for me, really had my hopes up. I guess build pics will have to do.
__________________
CaseLabs Mercury S3 | i7 4790k | Maximus VII Impact | GTX1080 | 16GB DDR3 | 512GB NVMe
Acer Predator Z35P | Corsair K70 LUX RGB Cherry MX Brown | Corsair Scimitar Black MMO Gaming Mouse
  #6
Old 25-01-17, 06:26 PM
tinytomlogan's Avatar
The Guvnor
Reads like you cant fit the rad in the roof, I think you need "with my OOOOGE memory"
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #7
Old 25-01-17, 11:42 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Totally wicked dude really looking forward to seeing how it all turns out for you, best of luck to you and have fun!
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #8
Old 25-01-17, 11:51 PM
Wraith's Avatar
Bettyswollocks
Definitely OOOOGE! Doms are really big compared to LPX or the Avexir dimms. They are not small rig water cooling companions.
__________________
  #9
Old 29-01-17, 05:02 PM
Wraith's Avatar
Bettyswollocks
So eventually I get around to flicking through 100s of potato images to show the goods properly, thus far I have stripped and prepped everything for reassembly but before that can take place I need to install the Mark S and do all the usual Windows 10 garbage as most of you know my rig is a working rig and is used everyday. So installation into the Define C will happen next then once the tube cutter and 4 pin PWM splitters arrive it is on for getting wet, nerves have gone now and excitement has taken over.
So here's the Alphacool gang chilling out.
Rads all cleaned out and ready for some fans.
GPU Block and back plate will be getting some colour and vinyl colour soon.
Likewise for the CPU pump/block/res combo.
Center stage for this build now is the Asus Z97 Mark S (Sabranco)
Isn't she a sight to behold. Until next time.
__________________
  #10
Old 29-01-17, 06:27 PM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
Looking good.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX1000-XSPC Raystorm Copper Edition-Dual D5 Pumps-Corsair Force 3 SSD-Sapphire Fury X2-Corsair 900D-Windows 10 Pro-Dell U3011-Dell 2007FP
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
