Thread Tools Display Modes
  #11
Old 13-12-16, 10:50 AM
Warchild Warchild is offline
OC3D Elite
I'm guessing its a custom mixed colour as it says on the tin
Whats my prize.
__________________
  #12
Old 16-12-16, 10:27 AM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
Hey guys,
The custom paint for the main panels is now finished! The parts that are still black are scuffed as I was going to do them silver as well however I decided to leave them and it works out better this way. I will just need to re-spray them black now in order to fix up the scuffing.
Anyways, let me know what you think so far! Stay tuned as there's more to come!
Thanks for checking it out!
Cheers,
Alex
  #13
Old 16-12-16, 10:28 AM
ciobanulx's Avatar
Advanced Member
Whats my prize.
Hahaha well... you didn't guess the colour. Anyways, new update is now up. Let me know how you like it
  #14
Old 16-12-16, 12:07 PM
OC3D Elite
I just hope its some metallic paint colour. Because those just pop and look amazing when applied properly.
Gloss and satin are nice, but nothing beats a good metallic tint.
__________________
  #15
Old 16-12-16, 10:12 PM
ciobanulx's Avatar
Advanced Member
It is a nice metallic with some nice sparkly flakes in it, not sure if you saw it as it's already up
  #16
Old 25-12-16, 11:08 AM
ciobanulx's Avatar
Advanced Member
Hi guys,
Merry Christmas! Just wanted to do a quick update on the build
With the majority of the case work now finished I will have to turn to the smaller details now and you guys will get to see that in due time.
Before that I want to showcase some of the components, the new H100i v2 and the Corsair HD120RGB fans. I am very excited for getting to use these fans
I'll have more updates in the new year or sooner if I can
Cheers,
Alex
  #17
Old 28-12-16, 11:22 AM
ciobanulx's Avatar
Advanced Member
Hi guys,
A quick update on the PSU shroud design I am doing
Just needs a bit of a clean up and some clear coat
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
  #18
Old 28-12-16, 11:24 AM
WYP's Avatar
WYP WYP is offline
News Guru
Ooo, very nice. I look forward to seeing more.
__________________
One of these days I'll change my name to Mark Bench
  #19
Old 30-12-16, 11:08 AM
ciobanulx's Avatar
Advanced Member
Thanks a lot
  #20
Old 30-12-16, 11:22 AM
ciobanulx's Avatar
Advanced Member
Hi guys,
I have a few more photos to share on the project however beyond this point I can't really share much due to NDA stuff. The build will be finished shortly and very soon I will be able to show everything so stay tuned.
I have most of the core components in at this point. I just need to finish the rest of the panels for the case and a special effect for the outside glass panels. Half of the cable management is done as well with all the fans and H100 cables sorted. There will be a cover panel going over this area which I shared before.
Cheers,
Alex
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
