Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #4831
Old 27-07-21, 02:55 PM
Bartacus Bartacus is offline
OC3D Elite
That looks INSANELY useful. I have multiple large displays, 35", 43", and the large bases are the worst part of them.
__________________
Games: Ryzen 5950X on GB Aorus Master X570 / Asus TUF 6900XT / 32GB TridentZ Neo 3600CL16 (16GB x 2) / custom loop
Workstation: Threadripper 2950x on GB Aorus Xtreme X399 / Zotac 2080ti / 32GB TridentZ 3200CL14 (8GB x 4) / custom loop
Home Theatre: Ryzen 3900X on Asus C7H X470 / Radeon VII / 16GB G.Skill 3600CL15 (8GB x 2)
/ custom loop
  #4832
Old 04-08-21, 08:15 AM
AMD Enthusiast
Researchers bypassed tpm and got the encryption key. In 30 minutes with little trouble and commonly available tools.
https://arstechnica.com/gadgets/2021...in-30-minutes/
How? Well board makers are cheap. They send the information over unencrypted lanes which makes it easily readable.
They need physical access to the device, but point is there needs to be improvements from board makers and on the software side to ensure information that is supposed to be encrypted stays encrypted on it's entire pathway.
  #4833
Old 04-08-21, 08:44 AM
tgrech tgrech is offline
OC3D Elite
This hasn't got much to do with cheaping out on anything tbf, there's nothing board manufacturers can do to suddenly make the SPI or i2c protocols secure, it's just an issue with how TPM works by design in the vast majority of setups, one simple solution is to just use the encrypted parameter feature of TPM modules so the important data is encrypted before it goes into the SPI or i2c lines.
  #4834
Old 04-08-21, 08:52 AM
Warchild Warchild is offline
OC3D Elite
Its quick news tgrech, not really the place to dispute or discuss. Make a thread instead.
*edit Perhaps moderators should delete all discussions, replies and such that are not quick news per se in future, without explanation. Including this message
  #4835
Old 04-08-21, 08:56 AM
OC3D Elite
I don't think the Quick point I added to the news warrants a new thread tbh, but ill add it there if one appears
  #4836
Old 04-08-21, 05:24 PM
looz's Avatar
looz looz is offline
OC3D Elite
Another forum I frequent has a similar thread, but it's for deals. There's two:
Deals (No discussion)
Deals (Discussion)
Maybe similar system could work here? Since relevant news would fade away eventually.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #4837
Old 26-08-21, 03:01 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
3090 SUPER -
https://videocardz.com/newz/nvidia-g...-gddr6x-memory
__________________
= Steam/Origin/Uplay - Dicehunter =
  #4838
Old 27-08-21, 01:33 PM
Dicehunter's Avatar
Resident Newb
Take with a grain of salt as it comes from a "leaker".
Apparently Blizzard is being renamed and many staff will be fired, WoW is being put into maintenance mode so no new expansions ever, A new "WoW 2.0" is in the works with a brand new team, Overwatch 2 has been cancelled.
https://www.mmo-champion.com/threads...(Leak-Spoilers)
__________________
  #4839
Old 27-08-21, 04:27 PM
WYP's Avatar
WYP WYP is offline
News Guru
Goodness, that is a huge change if true. I don't see overwatch 2 getting cancelled though. It is too deep in development.
Things are a mess with Activision Blizzard though.
  #4840
Old 27-08-21, 06:53 PM
OC3D Elite
So was project Titan, which was intended to be the new MMO. This cancelled project was stripped down and became what overwatch is today. So I would never put a sure bet on the outcome. Given the dire straits right now, anything is possible.
Maybe they will gut the company and start a new. They certainly have the finances to recover in that way.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
