Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 31-10-18, 12:45 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Corsair SF600 v2 Platinum DOA
I think I must be one of the most unlucky ppl with hardware lately. Finally got me a 3rd ITX motherboard that ACTUALLY works, then my brand new Corsair SF600 v2 PSU seems to be DOA. Keeps tripping the fail safe when powering on, and PSU tester just keep beeping although it reports no errors in the display. Tested with another PSU and everything works then.
Already opened up a ticket on the Corsair site, but knowing this might take weeks to get resolved I just ordered a new one from Komplett. Can't wait for this BS any longer.
  #2
Old 31-10-18, 12:53 PM
tinytomlogan's Avatar
The Guvnor
Try the standard cables.......
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 31-10-18, 01:02 PM
tolagarf's Avatar
OC3D Crew
Those ARE the standard cables. But the system won't post now with the other PSU. Guess I'm a bit confused now
  #4
Old 31-10-18, 01:11 PM
The Guvnor
Try the other PSU on your tester
Swap the PCIE cables if you have them. Ive know aftermarket cables come with PCIE cable errors and it would cause them to not start
__________________
  #5
Old 31-10-18, 01:13 PM
Corsair Pascal Corsair Pascal is offline
Corsair Rep
tolagarf please PM me your ticket number
can you try it with the other PCIE cables please?
  #6
Old 31-10-18, 01:53 PM
tolagarf's Avatar
OC3D Crew
Ticket no. 801378
For some reason the SF600 tripped first couple of times, but doesn't no longer. It might have been my mistake, and the constant beeping with the PSU tester might mean nothing. Could be just because the PSU tester is too old I guess? I'm not even sure what those beeps mean considering everything it reports in the display seems fine.
  #7
Old 31-10-18, 02:21 PM
tolagarf's Avatar
OC3D Crew
These are not aftermarket cables, those are standard cables included with the new version of the SF600 PSU
  #8
Old 31-10-18, 04:21 PM
The Guvnor
Doesnt matter, we were just trying to help work out what the issue might be.
__________________
  #9
Old 31-10-18, 04:49 PM
tolagarf's Avatar
OC3D Crew
And it's appreciated Tom, however there were no other cables to test with. I can't magically pull them out of thin air
  #10
Old 31-10-18, 05:06 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Does the PSU start with the paper clip method? you sure the tester isn't dodgy?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
