  #11
Old 08-07-13, 07:36 PM
Zanc Zanc is offline
Member
Radiators spot will pretty much depend on the size of the dvd/blu-ray writer. I think im gonna also replace the white fans with the Bitfenix spectre pros too, dont want to ruin the color scheme Might also paint the HD bay and the empty pci slot things on the back dark red too (if i get the motivation and proper gear for that)
  #12
Old 08-07-13, 08:03 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Making the colour scheme work overall would be a great idea! Don't go for too dark red though, the one on the mobo and videocard should look good
You can also mount your blu-ray burner (assuming you have one?) in the bottom 5.25" bay, or get an external one if you don't have one yet anyway. Keep that for emergencies but for most things you won't need a DVD burner anymore these days
Replacing the fans would be good. You can just use the built in fan controller and set your fans to 5 volt (7 when you're gaming) and it should be pretty inaudible but still cool well. If there are not enough connections on the integrated fan controller you can buy a Molex > (multiple) 3 Pin adaptor at 7 volt and plug your fans into that. You won't be able to adjust their speeds, but they will be quiet enough and still perform really well
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #13
Old 08-07-13, 08:16 PM
Member
Im removing the white fan from back and replacing it with 140mm BF Spectre pro red led. Also moving the one from top to the front. I will replace the 2 in the front on the next payday. Also added the SSD to the shopping card. The whole package is 1628.40€. Just a little over the budjet but I think I can handle that
Thank you for all the help and advice, Feronix! I owe u one
  #14
Old 08-07-13, 08:31 PM
Feronix's Avatar
OC3D Elite
Sounds like a good plan! I always tend to go slightly over budget because you can always get just that bit more performance
No problem mate, I'm happy I could help! You don't owe me anything
Enjoy your build and don't forget to post a build log and rig gallery here
__________________
~Rick
  #15
Old 10-07-13, 03:25 PM
UKCurtis UKCurtis is offline
Member
All I'm saying a SSD changes alot Just having that 1tb I would say is abit stupid, just have your OS running on the SSD and games ect on the 1TB. Also you could put a couple of games which you play alot on the SSD, You will be missing out I'm sure you could spend a little more for a SSD.
  #16
Old 10-07-13, 03:50 PM
Feronix's Avatar
OC3D Elite
...I'm pretty sure that he said he'd already added it to the shopping cart.
__________________
~Rick
  #17
Old 10-07-13, 03:59 PM
Member
Ohh sorry mybad silly me my mistake then. =)
  #18
Old 10-07-13, 07:06 PM
Member
Yep, it was added to the shopping cart, now im just waiting eagerly for the parts to arrive!
  #19
Old 10-07-13, 07:12 PM
Feronix's Avatar
OC3D Elite
Do a project log!
__________________
~Rick
  #20
Old 10-07-13, 08:04 PM
Member
I will certainly try to, I just got a lot of work and other obligations till the 5th of August. Besides, I am gonna order some additional things a bit later as well. I will take pictures ready, but i will post the full log when the build is completely done!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
