12-11-20, 01:34 AM
OC3D Elite
Thankfully with the O11 Dynamic XL, you can have your cake and eat it too. No airflow issues in that thing, provided you load it up properly, but you do pay a premium.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
12-11-20, 03:35 AM
OC3D Elite
I guess that is the end result when a manufacturer actually partners up with one of the best modders and overclockers in the world.
12-11-20, 03:46 PM
OC3D Elite
I had my cake with the case I have. It was my own vanity and stupidity that has caused the issue. Lian Li made it breathe perfectly.
Even with the front panel fitted the temps were exactly the same. It's when you go full dumbass and do this.
And add 1/2" thick halos that it has trouble.
__________________
If you don't like what I post don't read it.
13-11-20, 10:53 AM
OC3D Elite
How I feel right now.
__________________
17-11-20, 11:47 AM
OC3D Elite
Time to replace the old modded 360 controller, love the feel, the new pronounced grip texture is insane, and it's the best Dpad I've used in a long time, perfect clickyness
19-11-20, 01:56 PM
Resident Newb
Pre-ordered the 5900X, I really thought about getting the 5950X but I couldn't justify the extra cost as the extra cores and threads would be wasted plus there isn't much if any difference between the 5900X and 5950X in games, Should get it around December and then I'll sell on my 3950X.
Update
Had to cancel due to unforeseen financial circumstances
__________________
The majority of people on this planet have a disease I like to call "The Dumb".
19-11-20, 02:47 PM
Advanced Member
Had enough of the old 360 controller time for something new, PS4 pad can stay on the PS4 from now on, won't be ordering a PS5 anytime soon, but I'll use this for Cyberpunk
Pad, cable and next day post £71 they don't give you a cable with the pad now they want to bleed you dry like a wet stone full of silver crushed into a paste and melted into bars!!!!
Gabe added support to steam, then just add non steam game to get controller support for games outside of steam nice and simple
__________________
20-11-20, 12:13 PM
OC3D Crew
Some additional pliers, an assortment of 4mm hex screwdriver bits, a new soldering iron tip, oscilloscope probes and an assortment of components for my DIY valve amplifiers.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ 32GB Team 3200C14 ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ GTX 780 3GB
Enthoo Primo ⁞⁞ Seasonic Prime 750W ⁞⁞ Polaris SM961 256GB ⁞⁞ WD SN750 1TB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD 6TB, 4TB & 1TB
Samsung C27HG70 ⁞⁞ Ducky Shine 5 ⁞⁞ Intel X710 NIC ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B
20-11-20, 03:35 PM
OC3D Elite
One of these to prepare for a bigger GPU:
 But this cable construction confuses me, both the PCI-E aux cables are like this:
 Like how is that supposed to be neat. I suppose I've gotta shim one of the pins out and reroute them straight.
__________________
i7 8700k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
23-11-20, 05:55 PM
OC3D Elite
Purchased this Omen 15 inch laptop to replace my dying msi laptop which is suffering from severe framedrops due to overheating, having already replaced the thermal paste and cleaned it properly, its only when i totally underclock it, it doesn't throttle and drop down tot single digit fps, so enter,
Ryzen 5 4600h 6 core coupled with a GTX 1650ti and 8gb of ram on a ips display, nice upgrade from a 4th gen i7 and a gtx 850mobile.
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
Thread Tools |
Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
