Thread Tools Display Modes
  #61
Old 07-02-11, 11:21 PM
daantjuh44 daantjuh44 is offline
Member
If you do red and black themed sata cables too it will definatly look great the other way around !
__________________
  #62
Old 10-02-11, 07:22 PM
w3bbo w3bbo is offline
OC3D Elite
Send a message via MSN to w3bbo
I was just planning on having red cable for the SSD and black for the HDs (6gb/s vs 3gbs )
  #63
Old 10-02-11, 08:16 PM
wotevajjjj wotevajjjj is offline
OC3D Crew
Send a message via MSN to wotevajjjj Send a message via Skype™ to wotevajjjj
absolutly love this, wish i had the patience to do a build like this, i just trow stuff together, you make your stuff.
Love it !
  #64
Old 10-02-11, 10:43 PM
lappy74 lappy74 is offline
Member
This is just amazing.
Seriously great job!
__________________
Nice little fact: The diameter of our Galaxy, in miles, is almost the same number as the number of bits in 66831 TB.
  #65
Old 11-02-11, 09:55 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
you sire are a steely eyed missile man. Awesome Job. I am considering getting back into hardcore modding again but my budget suxs for it lol. I have a couple old build logs on another forum from when I did this before one I am extremely proud of the other well the thought was there but it lacked dearly IMHO in exacution.
But anyway SIMPLY AMAZING JOB!!!!!!!
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #66
Old 12-02-11, 07:14 PM
OC3D Elite
Before cracking on with the mootherboard prep I wanted to clear up a few odds and sods so 'carbonised' the GPU's to match the build:
Next up was the window mod.
The case came with a mesh panel:
but I prefer perspex, black tinted of course:
Needs a good polish with anti static but looks sweet in situ .
  #67
OC3D Elite
Time to finally start building. I seem to have spent so long preping and modding stuff .
Anyway here she is, the Rampage III Extreme:
The perfect motherboard to match the case and build:
After prepping the motheboard by removing the stock 'cement' with some MX-3 I set about mounting the heatsink, Prolimatech Super Mega:
Love the mounting hardware of the Super Mega. Easy but with 70lbs of pressure thanks to the optional black screws it should be effective .
Dunno if the copper fins will make that much difference but I managed to get the cooler for the same price as the all aluminium megalahems so I'm not not complaining:
Mounted:
  #68
Old 12-02-11, 07:16 PM
OC3D Elite
I originally had the Bitfinex Spectre 120mm fans planned for the HS but it made it look too black so I plumped for Prolimatech Vortex 140mm in push pull:
Memory in situ:
Sadly the board and tray together wouldn't fit into the case in one go thanks to the size of the cooler so I had to hide cables as I went rather than do a big cable tidy at the end of the build:
I also used the same fans on the intake door:
  #69
Old 13-02-11, 03:02 PM
TheWhiteRose000's Avatar
TheWhiteRose000 TheWhiteRose000 is offline
Member
Send a message via AIM to TheWhiteRose000 Send a message via MSN to TheWhiteRose000 Send a message via Yahoo to TheWhiteRose000
I can't too see the entire thing fully completed.
I'm already impressed.
And wondering what I can do to mine.
xD
__________________
  #70
Old 13-02-11, 07:14 PM
lasher lasher is offline
OC3D Elite
wont be happy until those brown are replaced with these Webbo ... come on now!!
http://www.kustompcs.co.uk/acatalog/info_1966.html
Detail dude!
__________________
Biostar Tpower I55, I5 750 @ 4.2Ghz, 4GB Kingston DDR3, Custom water loop - Thermochill PA120.3, Heatkiller 3.0 LC, Laing DDC Ultra, XSPC res top, XSPC white hose, Asus 5870, Antec Quattro 1000, Lian Li PC-X2000, Win7 ultimate.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
