Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #31
Old 29-04-17, 09:50 AM
ermacos ermacos is offline
Newbie
what about the phanteks air cooler that surpasses the corsair h100i. I do not like a ready water-cooling solution as you pay allot for a limited time of use. If we could refill them and change tubing's (replace their parts, instead of throwing them away when the liquid evaporates or the tubings get bad)... then yes... but there is not any. 120-180 euros is allot of money for what they offer.
  #32
Old 29-04-17, 12:23 PM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
The Phanteks doesn't really cool any better than other similar sized air coolers. The R1 Ultimate, Thermalright Le Grand Macho RT, Phanteks TC14PE, Noctua NH-D15, they all perform within margin of error of each other.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #33
Old 02-05-17, 02:40 PM
KTM_RULZ KTM_RULZ is offline
Member
Originally Posted by NeverBackDown View Post
most enthusiasts would, but not everyone will. Especially those people buying the 1600/x CPUs. Either way, spending all that money on a cooler hurts the "cheaper" argument people, including me, would use. It'll still end up cheaper of course than an intel system, but still more money is still more money.
Not saying that I disagree with you, but a good AIO is like a good monitor. It will be there when you upgrade. Maybe one would add it latter if budget is an issue.
  #34
Old 02-05-17, 03:22 PM
Bartacus Bartacus is offline
OC3D Elite
I'd like to toss in one point people rarely (if ever) mention when talking about AIOs versus air coolers. Unless the AIO is tested PROPERLY, it's not a valid comparison. By properly, I mean if you REALLY want to test the heat dissipation capability of an AIO, you need to stress test for MINIMUM 1 full hour, if not 2 hours. The good thing about air coolers is you'll hit your "worst case" scenario much quicker. With an AIO, you don't hit the "worst case" scenario until your liquid temps max out, which takes a while since liquid heats up a lot slower than air. Anyone who buys an AIO, stress tests for 20 minutes, and then assumes they're doing much better than an air cooler is incorrect, and not taking that stuff into account.
Top end air coolers ARE comparable to AIOs. Back in the day, when I first went from a good air cooler to an AIO, I gained NOTHING in terms of temps. But that wasn't obvious until I stress tested for hours.
I know this is common sense to some of you, but I thought it was worth mentioning.
__________________
Guts: Ryzen R7 1700 / Asus CH6 Hero / 16GB G.Skill 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Intel 600p 1TB NVME / 6TB RAID0 array / 2TB RAID0 array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #35
Old 22-10-17, 01:59 PM
Piah Piah is offline
Newbie
I'm getting 59-60c using a gammax 400 using the same test. 3.9ghz @ 1.3125v
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
