Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #11
Old 26-04-17, 07:40 AM
Daiyus's Avatar
Daiyus Daiyus is offline
Advanced Member
This is slightly concerning. I am in the process of designing an SFF case and was hoping to put an R5 1600 under a Cryorig C1 in it. Looks like I may need to accept a slightly thicker design to accommodate a CLC...
  #12
Old 26-04-17, 07:53 AM
dihartnell dihartnell is offline
Newbie
Originally Posted by Streetguru View Post
I use the $25 Hyper T4 to cooler my R7 1700 at 3800-3900mhz @ 1.4V and it seems to work just fine, granted I've upgraded the fan to a 140mm High Pressure Venturi fan, but it's probably not too much better than the stock fan. fan ran at 100% RPM, controled by a Sentry Mix 2 fan controller, super handy to have btw
Rarely breaks 60C running in a hot shed.
I would highly recommend a deepcool gammax 400 instead though, as it has cut outs to fit RAM, i wouldn't be able to put RAM into the 1st slot if I needed to upgrade to 32GBs, since I can't turn the heatsink on AM4 anyways.
Those volts are very high for that clockspeed. You should be able to lower.
  #13
Old 26-04-17, 08:02 AM
AMD Enthusiast
As long as you don't go nuts on the volts I would say it shouldn't be bad. Just make sure the airflow is setup well so the hot air gets out asap and doesn't sit around heating everything else up
__________________
The Cost of Freedom -
"A price payed gladly, in the hopes that the free, live better."
  #14
Old 26-04-17, 08:06 AM
Daiyus's Avatar
Advanced Member
Thanks for the advice. I'm planning on having two 80mm fans on the top edge of the motherboard exhausting air directly out of the case with the C1 pulling cold air straight through the side panel.
I suppose I might not be able to get that magical 4GHz but it still won't be a slouch.
  #15
Old 26-04-17, 08:32 AM
prelepo prelepo is offline
Newbie
Is the 12v better or the 7v?
  #16
Old 26-04-17, 09:02 AM
tinytomlogan's Avatar
The Guvnor
With that cooler youll probably be lucky to get 3.6 tbh - assuming you want it quiet too. Manual volts will be a must.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #17
Old 26-04-17, 10:55 AM
Daiyus's Avatar
Advanced Member
Hmm. I wonder how easy it is to make a CLC from custom watercooling components; as in using quick-release fittings and an external reservoir when setting up but then removing the reservoir for operation. I don't have space for a reservoir but I could squeeze two slim radiators with slim fans and a pump in.
  #18
Old 26-04-17, 11:03 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
You would not be able to remove the res. Not without draining the loop. Well, unless you use QDC and they are expensive. What you are better off doing is having a fill port. Then you don't need a res. To make a fill port you need to fit a 3 way T piece in front of the pump return (so the water can feed in and be pumped around) with a straight piece of tube coming up to a fill port so you can put the coolant in.
I am about to do this to my rig called Riff Tamson. Keep an eye on the log. I do have a res, but, it needs to be looped up in situ and the top cap is blocked by the res above. So I am going to fit a fill port so I can fill the res "remotely". However, there is no reason why it would not work in a "resless" loop. The only other thing to ponder is that the coolant expands when it is hot and shrinks when cool so you would need to fit some sort of relief valve. However, you could just screw that into the fill port's G 1/4.
http://www.ebay.co.uk/itm/3219363466...%3AMEBIDX%3AIT
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
  #19
Old 26-04-17, 11:11 AM
WYP's Avatar
WYP WYP is offline
News Guru
At 7V fans are fed less power and spin at lower RPMs. This will make the system quieter, though the reduced airflow will allow temperatures to increase.
__________________
One of these days I'll change my name to Mark Bench
  #20
Old 26-04-17, 11:17 AM
silverninja54 silverninja54 is offline
Newbie
Old Corsair H100i
Im running an old Corsair H100i old style with AM3 mounting brackets on my Ryzen 1800x rig. I changed out the Corsair fans for Cougar fans which are half the sound levels of Corsair and my rig is running at between 30 - 40 degrees without the offset taken off, overclocked to 4Ghz it runs between 40 - 50 without the offset taken off under load overclocked it runs at 70 degrees on stress tests w/o offset taken off.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
