Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #11011
Old 04-07-20, 12:18 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by Eddie long View Post
nice looking bike
Agreed, that's lovely I'm not a MTB guy but I do like Cannondale.
__________________
  #11012
Old 05-07-20, 07:27 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Corsair H115i Pro XT RGB, I liked the Corsair A500 but only got it due to it being an open box sale and cheap as hell but the performance is pretty s$%t to be honest especially on a 3950X, I needed something that performed well and is nice and neat, Not too keen on 360 AIO's as they just look way too big and the performance difference aint worth the price so settled on the 280mm.
__________________
=AMD Ryzen 9 - 3950X + PBO - XFX 5700XT Thicc III Ultra @ 2100/1800=
  #11013
Old 05-07-20, 10:58 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Was it sponsored by Corsair?
  #11014
Old 06-07-20, 05:58 AM
Dicehunter's Avatar
Resident Newb
Yes...
__________________
  #11015
Old 06-07-20, 04:17 PM
looz's Avatar
looz looz is offline
OC3D Elite
Originally Posted by trawetSluaP View Post
https://i.imgur.com/3aFz2i9.jpg
Pulled the trigger on this today, not sure when it's arriving, though.
Does your unit have bad backlight bleed?
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #11016
Old 06-07-20, 04:22 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is online now
OC3D Crew
Theres some, not noticeable when gaming, at least for me.
Not sure if it's the higher refresh or the curve but I#m getting headaches and motion sickness when using it though.
__________________
Enthoo Elite | i9-7900X | Rampage VI Extreme | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | S2721DGF, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #11017
Old 06-07-20, 05:48 PM
AMD Enthusiast
Try using it from farther away? See if that helps? Just as a test run. If it solves the problem it could be the brightness causing the eye strain headaches.
For me if I use any electronics or put my glasses on right after I wake up I will get the eye strain headaches(I believe most common type is called a tension headache) throughout the day. I have to ease myself into it. This might be your problem if the 600nits is causing discomfort. It could be to large of a jump from normal ambient light to that level of brightness for your eyes
  #11018
Old 06-07-20, 05:55 PM
looz's Avatar
OC3D Elite
Generally the radius of a curved monitor is also the maximum recommended viewing distance.
__________________
  #11019
Old 09-07-20, 05:38 AM
Dicehunter's Avatar
Resident Newb
I've been waiting for a VR headset with great lenses and high res for ages, As I mainly play Elite Dangerous in VR the washed out colours and aliasing even with the Cosmos is for me at least, An eye sore.
Pre-ordered the HP Reverb G2 VR HMD after seeing multiple videos, Based on early lengthy previews from trusted VR centric channels, It's the best HMD for picture quality/colour you can get, Made in conjunction with Valve and Microsoft.
Specs - 2160x2160 per eye, Combined resolution of 4160x2160, Total pixel count of 9,331,200, Compare that to the Valve Index's 4,608,000, This thing packs a hell of a visual upgrade as well as having the biggest sweet spot out of all available HMD's on the market.
Audio is the same as the Valve Index as it uses the exact same built in headphones, Lenses are out of this world for colour apparently, FoV is 114', Refresh rate is 90Hz, Hardware IPD adjustment, Inside out tracking etc... quite looking forward to these, Will probably arrived around September or so
Through the lens early look at the lens and picture quality, Absolutely gorgeous !
__________________
  #11020
Old 09-07-20, 07:16 AM
Warchild Warchild is offline
OC3D Elite
Preordered one too.
So with my index on its way, I have quite the VR collection.
Rift
Cosmos
Index
and soon to add, a Reverb G2
Sadly its more than you mentioned. 7500kr / £633
But oh well. Ive said £300 on public transport due to Covid 19 these last 3 months so it balances out. Launch date says 10 Sept in my email
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
