Go Back   OC3D Forums > [OC3D] Customer Care Forums > Aquatuning Customer Care
Thread Tools Display Modes
  #11
Old 17-05-13, 03:13 PM
Spiderz's Avatar
Spiderz Spiderz is offline
OC3D Crew
Originally Posted by SuB View Post
A Corsair SP140 or similar from Noctua would seriously get my attention...
An SP140 priced the same as the AF140 would sell like hotcakes and demand for 140mm rads would probably go through the roof too. Is there a standard fan spacing on 140mm style rads just now?
__________________
Current Rig:
NZXT H440 White, Corsair RM550x , AMD Ryzen 5 1600 w/ Cryorig H5 Universal, MSI GTX 1660 ARMOUR OC, 1TB HDD, MSI x370 Carbon Gaming Pro motherboard, 16GB RAM, Samsung 840 Evo 250GB
  #12
Old 17-05-13, 03:59 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Not yet afaik. I think 15 mm is more prevalent and might possibly prevail in the long run, but
some radiators still have 20 mm spacing (Hardware Labs, for example, at least the ones I
have).
While we're on the subject of radiators: I have had it happen on occasion that I've ruined an M3
thread while mounting a radiator to my case, despite being quite careful. If the Alphacool rads
could come with some more solid threads (possibly 6-32 UNC, but I'd much prefer M4) that
would definitely be a small detail I could get behind. The HW Labs SR-1's I have do have M4
threads, and it really does make a difference. I know of course that then all those shiny copper
M3 screws Alphacool has been making (which I love by the way) would have to be
switched to M4 (or whatever new thread size is implemented), but one can dream
  #13
Old 17-05-13, 04:22 PM
alienware alienware is offline
Banned
Send a message via MSN to alienware
How about you make a truly affordable 240mm water cooling kit.
Like the H100, but customisable. Yeah yeah, I know there are other companies who sell these kits but they're stupidly priced. The H100 is about £90, these kits from other companies cost £240 or so. That's bloody ridiculous.
What I'm saying is if you can make water cooling affordable you will bring it to the masses. Right now it's so expensive it just makes me LOL, not consider using it.
  #14
Old 17-05-13, 04:35 PM
SieB's Avatar
SieB SieB is offline
OC3D Elite
Those kits are reasonably priced to be fair, a H100 is a closed loop and is only for your CPU.
With the kits you get a much better rad, which will get you better temps and be much quieter because you don't need your fans spinning as fast to shift the heat. You can also add other rads into the loop as well, which is something you can't do with AIOs.
To watercool properly and it be worth it, those kits are the bare minimum you should be getting anyway. For it really to be worth it you want to go with a 60mm or above though.
__________________
NZXT Switch 810 - Ryzeny 3600 - Gigabyte X570 Gaming - 32GB Corsair Platinum SE - MSI Gaming 1070 - Crucial MX100 256GB SSD - Crucial MX500 500GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #15
Old 19-05-13, 12:48 AM
Aquatuning's Avatar
Aquatuning Aquatuning is offline
Member
Forgive me i havent had a chance to properly read through all the posts (I will come back to them) but i can answer this one quickly
http://www.aquatuning.co.uk/product_...U---Black.html
Fully upgrade able - full copper rad. or for the full "custom" experience:
http://www.aquatuning.co.uk/product_...-XT---kit.html
both of these will spank closed loop coolers
  #16
Old 19-05-13, 04:16 AM
AMD Enthusiast
Not so much an Aquatuning problem because i can't buy from them(they're in UK i'm in US) but if somehow they can get more companies to make product kits that are competitively priced to XSPC's full kits. I see their kits for 100$ less than others(granite not as good) but its the least expensive option compared to others. So if anyone wants to go real WC then they don't need to spend as much over a h100i..
But what more companies can do is get some more AMD 7xxx blocks. I find them very limited compared to Nvidia.
__________________
I am Iron Man.
  #17
Old 19-05-13, 04:35 AM
airdeano airdeano is offline
OC3D Elite
i live in arkansas and have purchased from aquatuning. cali isn't any different.
AquaTuning WebLink
got my stuff in 3-days and shipping wasn't to terrible. access to some items
the states does not have due to the european based companies. i wouldn't
order 5x fittings, unless there is no USA access.. something to keep on-hand.
  #18
Old 19-05-13, 06:53 AM
AMD Enthusiast
AquaTuning WebLink
Oh i was unaware! Thanks will keep them bookmarked along with other sites
__________________
I am Iron Man.
  #19
Old 19-05-13, 01:09 PM
Aquatuning's Avatar
Member
AquaTuning WebLink
This
  #20
Old 19-05-13, 01:39 PM
tinytomlogan's Avatar
The Guvnor
I'm behind the 140mm fan thing. I need to replace all mine cuz they're rubbish, but the alternatives aren't worth trying at £10 a pop... (i need 8).
Be patient
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
