Go Back   OC3D Forums > [OC3D] Customer Care Forums > Aquatuning Customer Care
Thread Tools Display Modes
  #11
Old 17-03-14, 10:21 PM
The_Governour's Avatar
The_Governour The_Governour is offline
OC3D Crew
WOW that looks very sexy! I would LOVE to see the same for a regular 780...... any up your sleeve??
  #12
Old 25-03-14, 11:46 AM
Aquatuning's Avatar
Aquatuning Aquatuning is offline
Member
It already fits the standard 780
  #13
Old 25-03-14, 12:12 PM
JR23 JR23 is offline
OC3D Elite
I don't like it on any aesthetic level. Incorperating detailing from the reference design is a nice idea but I don't find it well executed. None of the lines continue through the entire thing and all of the chamfers look entirely random if it's been done like that to fit around componenets then fair but it's just not coherent.
I don't get why the side pieces have 2 layers not one, if that's included as a design feature why doesn't the 2nd layer meet the corner of the chamfer on both sides instead of being perfect at one end and missing by a couple of mm at the other.
All of the text is upside down!
Why not write Titan where it is written on the ref. cooler and then make the X of NVXP align with the centre of the 'X' made by the 4 lines which intersect in the circle?
Also an Alphacool product without the 'αcool' logo? That is like the most killer logo in all of PC hardware
I don't like to be so negative and I appreciate there is far more work going into this than just the styling, making it perform well thermally and optimizing the flow/heat transfer are a bigger concern as well as just making it physically fit.
JR
  #14
Old 25-03-14, 12:17 PM
Aquatuning's Avatar
Member
Thank you for your opinions I will pass them on
  #15
Old 25-03-14, 12:22 PM
RickPlaysWarr's Avatar
RickPlaysWarr RickPlaysWarr is offline
OC3D Crew
Hmmm . . .
Not something I would pick. Part of the attraction/show/draw of water-cooling to me is seeing the coolant flow. Just a personal opinion really as I understand that if the block does its job and cools the component well; its all well and good. When I do get out of H100 land and build a custom loop for all the components, I will have lots of transparent/frosted/nickel blocks. Love the way they light up and show the "life blood" of the machine.
--Rick--
  #16
Old 27-03-14, 08:47 PM
OC3D Crew
NO !??? Do you guys ship to spain?
  #17
Old 27-03-14, 11:26 PM
Aquatuning's Avatar
Member
yes from www.aquatuning.de
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
