Go Back   OC3D Forums > [OC3D] Customer Care Forums > Aquatuning Customer Care
Thread Tools Display Modes
  #41
Old 21-05-13, 08:59 PM
Bartacus Bartacus is offline
OC3D Elite
Well I emailed these questions to Aquatuning support, but I figured I'd ask them here too, to cover my bases. Hope that's ok!
I have a few questions regarding Aqualis products I recently purchased. I bought the 880ml tube reservoir, but mine didn't come with the square bottom that is needed to connect to the Aqualis D5 pump top that I got from you. When I bought the tube, I didn't realize there were different versions. So given that:
1) can I purchase that square bottom piece separately? I looked on the website, but it only seems to come with reservoir kits.
2) if so, can I get one that will retain the waterfall effect with a D5 connected to the tube?
3) do you guys sell any mounting kits for the tube reservoirs that mount to the BOTTOM of a case? I want to mount the tube standing up (hopefully with a D5 mounted to the tube), but I don't have enough room to bolt it to a case wall. A case floor mount would be ideal.
Thanks for your time sir!
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
