Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #1
Old 10-01-20, 05:59 PM
joey117 joey117 is offline
OC3D Crew
Check Overclocked Setting Plz
I have a 3700x , asus x470-i , i hope the pic are good enough
https://imgur.com/a/aR6VzeZ
https://imgur.com/a/152p6zM
  #2
Old 11-01-20, 10:01 AM
RobM's Avatar
RobM RobM is offline
OC3D Elite
If thats stable then its ok, and you have a golden chip if it runs at 1.2 vcore. I would have expected 1.3 to 1.4 for 4.2 Ghz
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #3
Old 11-01-20, 11:15 AM
OC3D Crew
I use OCCT linpack for 12 hour with no problems, but i am checking a strange thing when starting from cold it will not boot , i clear the cmos and will start then i reapply them setting and all is well.
  #4
Old 11-01-20, 12:13 PM
FTLN FTLN is offline
OC3D Elite
Nice Volts !!
For your boot issue I have this issue also on X570, boot from cold gets stuck sometimes, power off and power back on and reapply my saved profile and it boots. I think AMD bios's are quite a bit more buggier than intel bios's when overclocking..
__________________
https://valid.x86.fr/6w9bi0
  #5
Old 11-01-20, 01:21 PM
OC3D Crew
I updated my BIOS this morning and and I was just looking to know the South bridge voltage on the 3700x what should it be , and for the voltage for the CPU I put it up to 1.275v I thought it might have something to do with the cold bug
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
