Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 23-11-14, 07:12 PM
mehere's Avatar
mehere mehere is offline
OC3D Crew
raising temps over time
Hi guys time to shout for ideas
I'm running a delided [email protected] with 1.216V on a Maximus 5 extreme
Its got a EK-Supremacy block on it mounted using EK's Precise Mount
the 2 pics show temps before/after reseating the block
the problem is that the temps will slowly raise back to the before temps over 3/4 weeks
on removing the block the tim looks as if it has gone really thin and been forced off the die
this has gone on for several months I've tried both MX-4 and NT-H1
the mount is just a screw it down to the stop type mount and I've even tried backing off on the spring tension in case its too much pressure forcing the tim out
now I'm out of ideas Help!
__________________
build log
  #2
Old 23-11-14, 11:32 PM
coalminer071 coalminer071 is offline
Newbie
http://www.coollaboratory.com/en/products/liquid-pro/
use this.
  #3
Old 24-11-14, 06:18 AM
mehere's Avatar
OC3D Crew
Originally Posted by coalminer071 View Post
but is this just a type of paste issue? as the temp's start of ok and MX-4 and NT-H1 are not cheap rubbish paste's
__________________
build log
  #4
Old 24-11-14, 03:37 PM
Warchild Warchild is offline
OC3D Elite
Ive used gallium aka liquidpro on my delidded cpu over a year. Much better and maintains temps. Idle is 25c and at load after witcher 2 session temp is 45c on an i3570k oc'd to 4.4ghz
I also use the ek stand offs or precise mount.
I dont suffer with rising temps. You just need an incredibly thing layer and thats it. In fact its so thin that it takes practise to spread it with a cotton bud
  #5
Old 24-11-14, 04:08 PM
mehere's Avatar
OC3D Crew
Ok thanks mate I'll see about getting some
edit got it ordered see how it goes
__________________
build log
  #6
Old 24-11-14, 05:43 PM
Newbie
nope NT-H1 is a paste that would have great results in the beginning, and would gradually rolll off the die afterwards. If your delidding. best bet is to use coolaboratory. However Its a pain if your going to switch waterblocks due to its sticky nature
  #7
Old 24-11-14, 06:48 PM
mehere's Avatar
OC3D Crew
thanks guys I'll let you know how it goes in a few days
__________________
build log
  #8
Old 27-11-14, 07:21 PM
mehere's Avatar
OC3D Crew
liquid pro is here, strange stuff to use for first time
lets hope it lasts longer than the others
managed to get to this
http://valid.x86.fr/f6z2af thats at load
__________________
build log
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
