Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #51
Old 01-04-17, 09:13 PM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
ouch, 1.45 for 4ghz.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX1000-XSPC Raystorm Copper Edition-Dual D5 Pumps-Corsair Force 3 SSD-Sapphire Fury X2-Corsair 900D-Windows 10 Pro-Dell U3011-Dell 2007FP
  #52
Old 01-04-17, 09:54 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by NeverBackDown View Post
Well I think as yields get better we have see better binned 1800x's. As it is now they really are all the same. There's no point in going for anything but the 1700, lower TDP but just as fast. Strange how it all worked out...
I think the guys have just answered that one. It obviously needs far more voltage to get up to the clocks of the 1800x, hence the massive hike in TDP. I bet the 1700 pulls some serious power with the sorts of voltages mentioned tbh.
Probably just early design. Maybe they designed it to run far slower, then had to push it to the limits in order to compete (same with the Fury X).
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
  #53
Old 01-04-17, 10:40 PM
AMD Enthusiast
No, it does pull less watts even when OC'd to the same speed.
__________________
Pickles are cucumbers soaked in evil
  #54
Old 01-04-17, 11:04 PM
AlienALX's Avatar
OC3D Elite
Wow, weird. Is that at the same voltage too?
__________________
  #55
Old 01-04-17, 11:53 PM
AMD Enthusiast
Yeah. I haven't seen a direct comparison, but at same clocks it's always consuming less, and considering how similar all Ryzen chips are voltage won't be far off each other
__________________
  #56
Old 02-04-17, 12:30 AM
AlienALX's Avatar
OC3D Elite
I think I have figured it out. The only thing left in the equation is that XFR thing. Maybe with it running on the CPU it uses up more power. I guess the only way to disprove that theory would be to disable it, and I'm not sure you even can?
That's the only difference left tbh.
__________________
  #57
Old 02-04-17, 05:40 AM
AMD Enthusiast
It would probably boil down to how aggressive AMD makes the CPU use it's power saving features(through the architecture itself I suppose or there ASEGA/whatever the hell it is called). XFR is disabled I am pretty sure once any manual OCing occurs. Even if you change to manual but keep the same settings, BIOS will turn it off. Not really sure, but it is consistently using less power even under OC load.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
