  #11
Old 17-09-13, 04:53 AM
AMD Enthusiast
"supposedly" yes. You would be better off going with a soundcard but in a mitx build that's pretty impossible with a gpu in there. If you really want better onboard audio then going to have to pony up some money for a higher end board.
  #12
Old 17-09-13, 06:37 AM
GaryC GaryC is offline
Newbie
Hmm.. In that case. I need to re-think my options here. I may have to go for an mATX case, after all.
  #13
Old 18-09-13, 01:58 AM
colin colin is offline
Newbie
Give this a try: ASUS Maximus VI GENE Motherboard
  #14
Old 18-09-13, 02:00 AM
Newbie
Yeah.. After looking around I think I'll completely change my build and go for a mATX build in a Corsair 350D. Fitting what I need into an mITX case is just not feasible.
Colin, the Gene is an mATX motherboard, but the pictures show an Impact.
  #15
Old 18-09-13, 04:25 AM
AMD Enthusiast
Fractal Design cases IMO are better than anything corsair has at the same price point. Might want to check them out.
Tags
1150, 1155, mini-itx, sff
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
