I've never tried this myself, so I really don't know. But simply going by spec, the 350D has a clearance of 160mm, give or take. If the cooler is spec'd at 160mm not including the heat pipes, then it's going to be a tight fit to the point that you might have some issues closing the side panel.
You should look into AIO coolers. They are more compact, easy to install, and more efficient.
