Thread Tools Display Modes
  #1
Old 14-12-07, 08:37 PM
FarFarAway FarFarAway is offline
Newbie
kempez's Project "Aqua vitae" 15/01/08 | Parts, ideas and test fitting
Before I start, MASSIVE thanks to the awesome folks at WCUK for sponsoring the project with some rather sexy bits and pieces (i.e. most of the water loops). If you want quality watercooling stuff talk to them
TFC, the makers of the fantastic Feser One, have shouted me two different Feser One colours, thanks again to WCUK...and thanks to feser One
As some may remember I am starting a project. This one's based around an A+ Black Pearl and I now have some hardware for it ready to start modding!
Basic ideas:
Two waterloops based around the fantastic dual res made by TribalOverkill. One for CPU (D-TEK Fuzion with high performance nozzle), one with EK NB and EK GPU cooler for 8800GTX.
The project is going to be orange and bluw...blue outside and orange inside with highlights externally. I'm currently working on the sketchup plans for it but am slow at that
There's going to be plenty of plexi involved and hopefully it will be a showpiece of detailed modding throughout...which means it may take some time
Etches are what I'm thinking of right now, the side panel window will frost out the drive bays and have something etched into it. There will also be a window in the top of the case to showcase the res.
Both waterloops should fit snugly in the bottom of the case, with 4 x high flow fans shifting the air.
I'll bring you more in the way of ideas soon but for now here's some pics of the bits and pieces:
Some appalling project sketches (note that rads are double and will match up with mesh lol)
Glad I'm a lot better at PS
Many more mods will be done than this but I'm just outlining a few to get the idea
  #2
Old 14-12-07, 08:48 PM
Luigi Luigi is offline
OC3D Elite
nice, looks good, want to see some work done
what did the guys at WCUK send you?
__________________
Luigi
Project: Flat Pack - Coming soon
  #3
Old 14-12-07, 08:51 PM
Newbie
I got sent:
240mm RAD for CPU loop *** GTS 240
240mm RAD for NB/GPU loop *** GTS240
UV fluid - orange and blue *** Sponsored by TFC
NorthBridge Block *** EK NF4
Clear 1/2" tubing *** XSPC 1/2"
On the way is:
8800GTX Full Cover block *** EK 8800GTX Acetal, although I think I may ask for a clear one as the NB block is clear
  #4
Old 14-12-07, 09:08 PM
Brooksie's Avatar
Brooksie Brooksie is offline
OC3D Elite
Gee that Black Pearl is huge!
__________________
3770k @ 4.5GHz | MSI Z77-GD65 |16GB Corsair Vengeance LP | MSI GTX670 Power Edition | Corsair AX850
  #5
Old 14-12-07, 09:10 PM
OC3D Elite
hopefully ill be getting myn to mod soon, except im going for quads in lower chamber.
Gosh, they sponsored you with a lot!!
__________________
Luigi
  #6
Old 14-12-07, 11:27 PM
Rastalovich's Avatar
Rastalovich Rastalovich is offline
OC3D Elite
I need a new camera lol.
Awesome build up m8.
__________________
  #7
Old 14-12-07, 11:48 PM
jabski jabski is offline
Banned
looking forward to see how you mount that res as i am using the same once i can get my 780i board
  #8
Old 15-12-07, 01:03 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
how did you make the 3d'age'isms?
looks set to be a sweet build mate keep us updated
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #9
Old 15-12-07, 01:38 AM
Marcus Marcus is offline
OC3D Crew
the modelling was done in Sketchup..
*looks at sig.. * hmm I recognise that model :P
  #10
Old 15-12-07, 02:05 AM
OC3D Crew
Double post but you'll get over it.. frosted acrylic here if you fancy it:
http://stores.ebay.co.uk/FORMAFAB_FR...QQftidZ2QQtZkm
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
