Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
  #21
Old 02-06-13, 07:12 PM
chrismjurd's Avatar
chrismjurd chrismjurd is offline
Advanced Member
never mind the ssd, your caviar is way out of wack. try running the 750gb just to test the difference incase of driver issue.
  #22
Old 02-06-13, 07:15 PM
InnocentDemonz InnocentDemonz is offline
Newbie
My SSD is a OCZ Vertex 3
and ok, il post pictures as soon as ive done it
  #23
Old 02-06-13, 07:49 PM
vorticalbox's Avatar
vorticalbox vorticalbox is offline
OC3D Elite
seems his whole system is having a massive hits on write.
__________________
Photo Blog
  #24
Old 02-06-13, 07:52 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
ahci enabled Trim btw lads, that SSD's write speeds look very lack-lustre. That 2TB drive looks like it's not doing great. I'd get a S.M.A.R.T. program and get it checked (google it you should be able to find a free one)
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #25
Old 02-06-13, 08:04 PM
Newbie
750gb hard drive results
Click image for larger version
  #26
Old 02-06-13, 08:15 PM
AMD Enthusiast
How much porn have you downloaded? Might just be a ton of malware in your system? Not saying that's the case but it's a logical one...
  #27
Old 02-06-13, 08:17 PM
Newbie
Ha Ha Non, this 750gb has pretty much nothing on it, it has a back up of my old windows 7 and a failed transfer of my steam games
  #28
Old 02-06-13, 08:20 PM
AMD Enthusiast
What bout yo other drives?!
  #29
Old 02-06-13, 08:28 PM
Newbie
there all up to date
  #30
Old 02-06-13, 08:29 PM
chrismjurd's Avatar
Advanced Member
From those couple of screenies, you can clearly see there is some issue with your WD Caviar drive, the 750gb drive scores are more in line with expected results, so if there is any way you can grab the stuff from your drive that you need to keep off it, ie your steam saves, or check whether your cloud sync on steam is upto date, then perhaps try a fresh format of the 2TB drive and rerun, else look into a checkup with WD and see what they have to say. iirc black drives have a 5 year warranty. would be worth a looksie.
Tags
angry birds, help needed, not working, steam
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
