Thread Tools Display Modes
  #21
Old 11-06-17, 12:36 AM
mb67's Avatar
mb67 mb67 is offline
Member
Getting closer to completion.
__________________
It might look like I'm not doing anything, but at the cellular level I'm really quite busy.
  #22
Old 11-06-17, 12:47 AM
Bartacus Bartacus is offline
OC3D Elite
Looking good!
__________________
Guts: Ryzen R7 1700 / Asus CH6 Hero / 16GB G.Skill 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Intel 600p 1TB NVME / 6TB RAID0 array / 2TB RAID0 array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #23
Old 11-06-17, 06:32 AM
mb67's Avatar
Member
Aaaand Nothing. It's stuck at Q Code 98 and won't go any further. I've swapped out keyboard/mice, used all the USB ports available (except BIOS), swapped RAM, Went to single GPU using both PCI-E slots, flashed BIOS, Cleared CMOS, and still nothing past Q Code 98.
I do eventually get this screen, but no keyboard/mouse capability...
__________________
  #24
Old 11-06-17, 09:27 AM
mb67's Avatar
Member
I fixed it! It turned out to be the NZXT Internal USB 2.0 Hub that was preventing the BIOS to finish.
__________________
  #25
Old 18-06-17, 02:57 AM
mb67's Avatar
Member
Just waiting on the SSD to arrive.
I've got it running at just over 4GHz, but I've not had time to mess around too much with it. Oh, I do have the RAM running at 3200MHz.
__________________
  #26
Old 18-06-17, 11:06 AM
Warchild Warchild is offline
OC3D Elite
I love the build, but that SLI block is quite horrendous!
you did a good job on the recolouring. Have you thought about repainting the aluminium colour on the gpus for a lighter/darker shade of purple for better contrast?
__________________
  #27
Old 18-06-17, 04:17 PM
mb67's Avatar
Member
I agree with you about that SLI Bridge- it's hideous. It's a temporary solution until the one that I want comes back in stock.
I was toying with the idea of painting the GPU's, but I kind of think that it would be too much color. Instead I've got an SSD on order which will go underneath the ROG emblem, but I plan on using an acrylic cover for it with a contrasting color.
  #28
Old 29-06-17, 11:56 PM
mb67's Avatar
Member
I got the SSD and custom cover installed. I'm in contact with someone who is able to do a custom back-lit cover that I can use instead of the ROG emblem.
The last thing afterwards is waiting for the SLI Bridge that I really want to come in.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
