Thread Tools Display Modes
  #71
Old 30-10-16, 12:19 AM
Surfie's Avatar
Surfie Surfie is offline
OC3D Crew
Originally Posted by AlienALX View Post
Can you get blue fan things? it would look sooo much better.
Fan things? You mean the rings?
The mb lights up red when powered as well, so i think it actually accentuates that, which is why i chose to leave them red.
__________________
What we've got here is; failure to communicate...
  #72
Old 07-11-16, 02:33 AM
Surfie's Avatar
OC3D Crew
Well, here we are. At the end of the project.
I have managed to boot the PC up, and get it installed in it's new home...
This home is a temporary home - until I get myself a bigger/more appropriately sized desk. But for now, it will do!
I hope you have enjoyed the journey as much as I have!
__________________
  #73
Old 07-11-16, 04:49 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Looks good but my only critique is the red accents with all the blue just don't quite look right
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #74
Old 07-11-16, 04:59 AM
Surfie's Avatar
OC3D Crew
I understand, it's a bit vegemite. Unfortunately about half of it is red leds built into the board, and i have no idea on how to change that.
If i could, then i would consider modding the mb by painting it and switching out the leds.
__________________
  #75
Old 07-11-16, 12:45 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Like it but yeah, that red. I wish you could get push on PCIE covers. Well, that or I had a 3D printer
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
  #76
Old 07-11-16, 08:27 PM
Bartacus Bartacus is offline
OC3D Elite
Just fill up the PCI slots with another GPU and an NVME SSD. That'll cover the red nicely.
__________________
Guts: Ryzen R7 1700 / Asus CH6 Hero / 16GB G.Skill 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Intel 600p 1TB NVME / 6TB RAID0 array / 2TB RAID0 array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #77
Old 06-06-17, 12:57 PM
Surfie's Avatar
OC3D Crew
Sorry for the necro, just providing a quick update regarding the colour of the fluid 6+ months later, and advising of an update that is currently being planned for when i do the next lot of maintenance (probably in 5-6 months).
The colour has not changed as yet. It is the same blue as the day it was originally put in. I have not got particularly hot components though, so maybe that is why.
I'm currently planning on addressing the red comments from earlier. Long term, the fix will be to buy a black motherboard and updated cpu, but for now, I'm thinking of the quickest avid easiest way to cover it up, without risking the board itself.
If you guessed "vertical gpu" then you are on my wavelength. I bought the cooler master vertical bracket, and intend to remove all the pci slots when i do my next year down. Due to this by necessity changing the tubing runs, i also intend to decouple the pump/res (making then two independent units), turn the 360 rad on its head, and hide more of the tubing under the false floor i created.
I think that this will make the aforementioned red much less onerous, as well as cleaning up the lines of tubes.
Thoughts?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
