Go Back   OC3D Forums > [OC3D] Customer Care Forums > Time To Live Customs
  #1
Old 02-05-16, 07:56 AM
FatBoiCorp FatBoiCorp is offline
Newbie
False Floor/Wall
Hey everyone,
It has been awhile since I been here. I had the urge to finish up/tidy up my own build.
I am planning to make a false floor for the bottom of the case and a false wall for the motherboard part.
My question is, What material should I use to build the wall/floor? Should I use a metal or acrylic material? or do you recommend a different type of material? I also have a question about making the holes for the wires in the false wall, Is there a much neater way to make them besides making a hole and putting a grommet on the hole?
Thank in advance. =)
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
