Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
  #1
Old 26-12-12, 03:24 PM
leathart123 leathart123 is offline
Member
4 ssds in raid 0 or is it just a head ache
i am thinking of buying 4 cosair neutron gtx 480gb to attach to my rampage 4 extreme just so that i can have epic read and write speeds for the photo editing I do. I was wondering whether it was going to be a nightmare or if it would be epic
  #2
Old 26-12-12, 03:27 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Waste of time IMO. Not sure what software you use to edit photos and what sizes you are working with, but I'd imagine you would see little to no difference between 1 SSD and 4 SSDs in RAID 0. Benches will be quite different for sure, but you will gain nothing in real world performance.
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 32GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #3
Old 26-12-12, 03:28 PM
MadMarc's Avatar
MadMarc MadMarc is offline
OC3D Crew
The rampage 4 extreme only has 2 sata 3 ports (only two on the intel controller) so you could only use 2 ssds in raid 0,
I agree that it won't be worth the money
__________________
Tags
4 ssd, raid 0
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
