Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
  #10661
Old 25-03-20, 08:15 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Oh wicked. I can't see it being tremendously different from the Z tbh. Which I really liked when I had one. I *think* it's the same processor, just much more shielding and better caps etc.
It's only for my headphones any way. I doubt I will connect speakers to the new rig given it's for gaming and VR.
__________________
If you don't like what I post don't read it.
  #10662
Old 28-03-20, 01:57 PM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
ZEN 2600,16gb Dimm kit @ 3200mhz, M-ATX mobo and a 500gb ssd....something to do in lock down!
__________________
AMD Ryzen 5 2600,Patriot Viper 4 16GB 2x 8GB 3200 Ghz,Gigabyte B450M DS3H,Patriot BURST 480GB SSD x2, MSI 5700, Aerocool White Aero One Mini Eclipse, seasonic m12ii 620w,Deepcool gammaxx 400 v2.
  #10663
Old 28-03-20, 08:29 PM
Kei's Avatar
Kei Kei is offline
OC3D Crew
EMI shielding on soundcards is a fallacy. This is the RME HDSPe AIO professional audio interface I use. No shielding and no boutique parts. Well designed and constructed using quality parts and not a sniff of EMI. It sounds equal or better than the creative cards and the asus essence ST I had previously. It annihilates them for latency and input quality and so it should considering the £500 it costs. (though I imagine a great deal of that is the xilinx FPGA it uses and the sheer number of in/outs and features it supports)
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ 32GB Team 3200C14 ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ GTX 780 3GB
Enthoo Primo ⁞⁞ Seasonic Prime 750W ⁞⁞ Polaris SM961 256GB ⁞⁞ WD SN750 1TB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD 6TB, 4TB & 1TB
Samsung C27HG70 ⁞⁞ Ducky Shine 5 ⁞⁞ Intel X710 NIC ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B
  #10664
Old 28-03-20, 10:36 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
Even though it beats consumer soundcards RME HDSPe AIO is considered to be by far the worst RME card. The sound from AIO is really bad compared to their external (read: External) interfaces/converters like Babyface Pro FS, ADI-2 Pro FS, or their Fireface series.
If even the mighty RME cannot pull out a good, clean analog signal from within the PC case that tells you everything you need to know about consumer soundcards. Forget internal cards and buy external solutions. Pretty much anything with external conversion will beat internal cards at the same price range and those way above.
The PC case is just too noisy for a quality analog audio signal.
Internal cards are good if they are fully digital like HDSPe RayDat and then you connect your external converters to it.
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
  #10665
Old 29-03-20, 05:32 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Originally Posted by trawetSluaP View Post
Even with a flash GPU will still report correct stuff won't it? Cores etc.
Looks legit:-
https://www.ebay.co.uk/itm/NVIDIA-Ge...rdt=true&rt=nc
We'll see.
Not sure how much you personally like him, but Linus did a video a while back on a GPU that was from eBay. Turns out it was a fake, the BIOS had been flashed and all sort of things. Programs showed it as a true GPU, yet the actual GPU die was a very old one and couldn’t possibly be what it was marketed at.
I’m not that into this whole area, but just thought I’d give you a heads up though.
  #10666
Old 29-03-20, 09:02 AM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Thanks, I changed the thermal paste and checked the die it is a genuine 2080 Ti but it's not working properly so it's going back.
Have dropped and risk and ordered a brand new car from a etailer.
__________________
5000D | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG| Custom Watercooling Loop + Aquaero 6 XT
  #10667
Old 29-03-20, 11:03 AM
tgrech tgrech is offline
OC3D Elite
Managed to find a New (Open Box) 860 EVO from a seller for just a little over £105, about the cost of the QVO model atm if you want it within a couple of weeks. Will run SMART checks to verify it's not used ofc as £30 off for an opened box seems a bit OTT.
But this will help me with a little toy I've got coming in the next few days.
  #10668
Old 29-03-20, 12:04 PM
SPS SPS is offline
Moderator
Finally moved away from gaming garbage and moved to Varmilo VA88M TKL w/ MX Reds, PBT keycaps and lubed stabilisers, it has zero rattle and it is a dream to type on.
Decided to have a break from using Browns for the past 3 years and try Reds - will be interesting to see how I find them.
  #10669
Old 29-03-20, 02:38 PM
Dawelio's Avatar
OC3D Elite
Not sure what you were using previously, but do you prefer keyboards with out an armwrest? For me personally, they have become a bit of an essential to me. Since every keyboard I've own have had it and it has been rather comfortable, felt odd to not have it. That being said, I just haven't found one without, that suited my needs though.
  #10670
Old 29-03-20, 02:46 PM
AlienALX's Avatar
OC3D Elite
That sucks. TBH the low feedback did worry me, but at least you have Paypal.
Nice keyboard SPS. You can't beat mech.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
