Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Gaming
  #21
Old 26-05-20, 10:51 AM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Originally Posted by Warchild View Post
Can tune what you want. I think there were some restrictions on driver assists though. Cant remember.
I only use what the car comes with for ultimate realism.
Gonna download and see how much slower I am than you guys.
__________________
Enthoo Elite | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #22
Old 26-05-20, 11:05 AM
SPS SPS is offline
Moderator
Oh, I thought we were keeping the tunes default to make it fairer? I've updated your time Warchild, I updated previously but not sure where I got that time from
  #23
Old 26-05-20, 11:07 AM
OC3D Crew
I'll stay default then.
__________________
  #24
Old 26-05-20, 11:49 AM
looz's Avatar
looz looz is offline
OC3D Elite
Did some hotlaps but I'm getting a bit frustrated Maybe it's due to bad sleep recently but man, last of the tight curves seems like you could catapult yourself in gear 2 and get a huge benefit, but only managed it on a lap which was otherwise... less than stellar.
I don't really understand the way this car works as in many turns, drifting is very fast, but in others, you lose like .4 like in the last corner. Needs work I guess.
Free Practice sectors before I realised that I'm in wrong mode
Time Trial sectors
Edit: Oh, also, my tune isn't default, I made the car stiffer. Feel free to discard the time for now, then. Which of the defaults should we use, circuit or rallycross? (Maybe the other was named gravel or something similar)
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #25
Old 26-05-20, 12:15 PM
Warchild Warchild is offline
OC3D Elite
im happy with default though. More transparent then.
  #26
Old 26-05-20, 12:17 PM
OC3D Elite
Time Trial sectors
Its about the gearing while you. Drifting in 2nd gear with high revs will drift smoother and more efficient than being stuck in 3rd at low rev.
The car doesnt seem to like cornering in 3rd. I dont mind you guys running tuned setups though. Gives me a challenge
If i get that time this week, You are doing the lottery for me
  #27
Old 26-05-20, 12:28 PM
SPS SPS is offline
Moderator
Well I'm not saying we shouldn't use custom setups, it's Wraith's challenge but I think it just keeps it simpler, what would you guys prefer?
Haha.
Yeah I think the car is fastest when drifting, not designed to turn corners
  #28
Old 26-05-20, 12:31 PM
looz's Avatar
OC3D Elite
I mean I definitely want to just use all stock after that "more challenge for me" comment from Warchild.
__________________
  #29
Old 26-05-20, 12:50 PM
OC3D Elite
I am happy either way. But default is much simpler and leads to more racing. I used to spend hours tweaking setups just for that 0.1s improvement. And getting frustrated by it too!
Let's leave it to Wraith though. As we Wheelers have a massive advantage over controller(ers), setups can make the controller(ers) :P have a fighting chance. But at the same time, it gives us an even greater chance to pull ahead.
  #30
Old 26-05-20, 02:18 PM
looz's Avatar
OC3D Elite
... I should've left it default in the first place.
1:02.880
__________________
Tags
challenge, oc3dracing, pcars, project cars
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
