  #1
Old 16-09-13, 03:37 AM
GaryC GaryC is offline
Newbie
Switch to Mini-ITX - Unsure of Pathway
I want to move to a mini-ITX platform for my computing needs, as an evaluation of my usage doesn't really need any more than that. I surf the internet, play games (the latest game I play is probably Civ V or Skyrim), watch movies and do protein folding, that's about it. A mini-ITX case has a smaller footprint, not to mention looking very sleek, so I want to move towards that direction.
I currently have:
CPU: i7 2600K
GPU: GTX 670
Case: CM 690 II Advanced
Mobo: Asus P8Z68 Gen 3 V-Pro (I think)
SSD: Samsung 830 256Gb
HDD: 3x 2Tb (2 in RAID0, 1 as backup)
PSU: Antec True Power 750
My plan is to get:
Case: Silverstone FT03 Mini
Mobo: UNSURE
CPU: UNSURE
HDD: 1x 3Tb
PSU: Silverstone SFF 450W (the 80+ Gold one)
CPU Cooler: Corsair H60
The SSD and GPU will be definitely moved across, and I can easily clean out the junk in my HDD and squeeze it into a 3Tb drive.
The only thing I'm unsure of is the CPU and Mobo. In terms of performance, sure, the Haswell CPUs are better, but is it better *enough* to warrant a $400 upgade including the motherboard?
Alternatively, I could just get a LGA1155 mini-ITX motherboard from eBay and continue using my 2600K, which is still more than enough for what I do. This is a lot cheaper, but it feels like I'm taking a step back, or, at most, a side-ways step in terms of 'upgrading'.
What's the better choice, in this regard? Thank you very much for your advice!
  #2
Old 16-09-13, 04:14 AM
NeverBackDown NeverBackDown is online now
AMD Enthusiast
Since i saw you use a $ sign i assume you are from the US? Should point that out as many on here are from Europe(not me)
So here are 2 motherboards i would recommend.
Gigabyte z87 mini-itx
or Msi z87I mini-itx
About same price and will suit you just fine. If you don't need the 4770k then just pick up the 4670k.
  #3
Old 16-09-13, 04:50 AM
Newbie
Ahh, apologies for the confusion. I put the $ as I'm living in Australia now. If I were to go towards the new cpu route: I'd probably get a 4670K as I don't see the extra cpu grunt necessary for my usage needs.
  #4
Old 16-09-13, 11:18 AM
jamesriley94 jamesriley94 is offline
OC3D Elite
I'd go for a P8Z77-i Deluxe and keep the 2600k tbh.
I'd go for a Prodigy rather than the Silverstone case though - or wait for some of the newer Bitfenix ITX cases to come out.
  #5
Old 16-09-13, 12:53 PM
Newbie
The whole idea was to keep it as small as possible. Alternatives I've considered included the Prodigy, but also the Node 304 and the Evga Hadron. I've also thought about an mATX mobo so that I could install a dedicate sound card.
  #6
Old 16-09-13, 12:57 PM
Jordan Jordan is offline
Advanced Member
I was going to say the same thing, the prodigy's are awesome.
  #7
Old 17-09-13, 12:21 AM
AMD Enthusiast
Node 304 isn't as tell but is longer.. All personal needs and IMO i think it's the best looking one and will easily handle whatever you want. All personal choice though.
  #8
Old 17-09-13, 01:24 AM
Newbie
Yeah, that's what's been vexing me. Too many choices! Other than the newly released Maximus VI Impact, are there other decent mITX motherboards with good onboard audio, but not that pricey? The VI Impact is almost $340 here
  #9
Old 17-09-13, 02:21 AM
AMD Enthusiast
Onboard audio is more or less all the same. Shouldn't be a sole reason to choose one over the other. Find one that has all your needs and get it.
  #10
Old 17-09-13, 02:27 AM
Newbie
Isn't the onboard audio supposedly much better on the Maximus VI Impact?
Tags
1150, 1155, mini-itx, sff
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
