Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
  #1
Old 18-01-13, 05:18 PM
SimonB's Avatar
SimonB SimonB is offline
Newbie
Send a message via Skype™ to SimonB
Cheap rusty pc works for me ;)
hi thnx for watching My rig ATM :
cpu: AMD Phenom II 965be 3.4/4ghz
gpu: Saphyre radeon hd 6950/6970
SDD: Patriot Pyro 120GB SATA3, Speeds 550/515MB (ps i know my mobo supports only Sata2)
HDD: SMG F3 1TB 3.5" SATA2 7200RPM 32MB
ram:2x4gb DDR III 1600mhz
psu:Fortron FSP HEXA 500W ATX v2.3/ Dual +12V Rails/ Silent 120mm FAN/ High efficiency >80%/ Active PFC PSU
hsf:Spire Thermax Eclipse II
monitor:Lg 22' Flatron w2261vp 0,2ms late only
case: not sure yet now its s.h.i.t.y 5$ case =} /
mobo:ASROCK M3A770DE
yea i knew it issint as prety as most of you all here but i bet noone ever put hdd and ssd in there =D i done it because i do plan of drilling out these hdd cage anyway i got case for free =} from outside it looks prety desent well i could do more with cable's but they are prety short this pc was made for like 600 punds with monitor and i did play all games max settings for my hd 1920x1080 res i do call this rig my gamer rig its cheap and eat games like ice cream (i put games in ssd because i ussualy play one by one) and my soft i use in ramdisc
__________________
Too tall - management
keep in mind i use wireless router =D
  #2
Old 18-01-13, 05:57 PM
seumasbeathan seumasbeathan is offline
Banned
I would recommend a new case :P
  #3
Old 18-01-13, 06:36 PM
G-sus's Avatar
G-sus G-sus is offline
Member
What he said. I learned the hard way that no matter how much you mod a crappy case, it's still a crappy case. Everything else looks good though Oh and clean up that dust
__________________
Asus M5A99X EVO R2.0
AMD Phenom II X4 965BE
XFX 7950
OCZ Vertex 4 128GB
WD Green 2TB
16GB Crucial Ballistix Tactical
Corsair AX760
Corsair 600T White
  #4
Old 19-01-13, 12:44 AM
Liarma's Avatar
Liarma Liarma is offline
Advanced Member
Considering how cheap a 200R is there is no excuse to use that POS LOL
__________________
Corsair 650D
2x Gigabyte GTX670 OC SLI
Intel Core i7 2600K 4.6GHz
8GB G.Skill Ripjaws X 1866MHz
Asus P8P67 Deluxe
120GB OCZ Agility 3
My Rig Gallery http://forum.overclock3d.net/showthread.php?t=46422
  #5
Old 19-01-13, 01:19 AM
BPRSM's Avatar
BPRSM BPRSM is offline
Member
Send a message via Skype™ to BPRSM
That's not that bad. As long as you like it that's all that matters!
  #6
Old 19-01-13, 01:26 AM
dragoonk dragoonk is offline
OC3D Crew
That looks strikingly similar with my case...
__________________
MB: MSI 760GM-E51 (FX)
CPU: AMD Athlon II x3 450 Rana @ 3,93GHz, 1,56 V
HDD: 1xExcelstor 160 Gb
GFX: Sapphire HD3870x2 857/1053
RAM: 2x2Gb Kingston HyperX Blu 1600 MHZ 1,65 V
PSU: Inter-Tech SL-700 700W
  #7
Old 19-01-13, 01:47 AM
Rich_ Rich_ is offline
Member
does that power supply actually say pyro on it? nvm that's not a psu.
__________________
Zalman Z9-U3
i7 3770k 4.5ghz
Corsair H70 Core - Xigmatech push, generic pull.
GTX 560 superclocked 930mhz
Zephyr 720W PSU
Crucial Ballistix Tracer orange/blue 4GB 1600mhz
Sandisk SSD 120GB
  #8
Old 19-01-13, 02:20 PM
SimonB's Avatar
Newbie
i told that u hadint ever seen hdd and ssd mounted like that anywhere =DD but it looks nise for me even cleaner then in the cage
as for 200r i dont like it and to buy such case i prefer buying atleast silverstone or cm haf or storm case instead than that ugly little case
um well case is under my desk so i dont care much about how it looks important thing is how it works =} and it does all i need atm but im thinking about waiting for new lines of cpus from intel and amd and probably gona switch to intel
__________________
  #9
Old 19-01-13, 02:29 PM
Banned
You completely just contradicted yourself lol, not buying the 200r because it doesnt look nice, "i dont care much about how it important thing is how it works"
The 200r may not be the best looking case but it certianely isnt the worst, and as for how it works, it is a great case
  #10
Old 19-01-13, 03:20 PM
iBeInspire iBeInspire is offline
OC3D Elite
Am I the only one who think's it's a tad overpriced for what it is..?
I would suggest a Shinobi or one of the cheap Antec cases ~
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
