Hello! Im Joe Campbell, Owner of YouTube channel Gadget Joe and im a reviewer/videographer and modder from Grimsby, UK.
My latest project build is Alter-Ego, a custom desk build (yes another desk build!) with a unique one of a kind twist! Work and play built into one unit with 2 systems and 2 different personalities!
Sponsored by Alphacool/Aquatuning and Mayhems.
Aquatuning and Alphacool sponsor all the liquid cooling components, radiators, tubing, blocks and more.
Mayhems sponsor the maintenance of the loop and system in form of Blitz Kits.
Specs:
(main system)
Mobo: Asus M5A97 LE R2.0
CPU: AMD FX 8350
RAM: Kingston 1600mhz 16gb (2x8)
PSU: 500w
GPU: Radeon RX480 8gb
SSD: 120gb Hyper-X
HDD: 500gb+320gb HDD
(watercooling loop - Parts being provided by Alphacool/Aquatuning)
Alphacool Eisbrecher Pro XT45 240mm Rad x2
Alphacool VPP655 Eisdecke D5 x2
Alphacool Eisbercher Lite 250mm Plexi x2
Alphacool Eisblock XPX CPU Chrome
Alphacool NexXxosS GPX 480 Gpu Block
Alphacool Susurro Fan 120mm x4
Multiple Alphacool chrome fittings
13/10 PETG and Soft tubing
Alter-Ego is a 6ft long by 38" wide desk with main system built into a white gloss box that sits at 24"x32" sunk into left hand side housing main system with polished glass top, Test bench with AIO to the right of the desk in an 8" recessed white gloss box. Top is burnt and stained pine, rest is white with burnt pine accents and LED backlighting and RGB LED embedded around the build. Wall mounted triple monitor setup. Power switches from main to test bench with one button. 2x reservoirs with different shades of UV blue each powering GPU Block and CPU block respectively, Hard tubing on top, soft tubing in hidden void underneath.
Acrylic detailing, sheeting and Gadget Joe and sponsor logos embedded throughout desk courtesy of Admodz
Pine top, MDF treated Carcass, Chrome Legs, Acrylic panels, Safety glass and sealants.
Main system will be white, blues and blacks. Test bench will be red, purple, black, orange.
Layout Sketches:
Build Poster with sponsor list:
Original Renders:
Specs:
(main system)
CPU: AMD FX 8350
PSU: 500w
SSD: 120gb Hyper-X
Layout Sketches:
Original Renders:
