OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   Off Topic Chat (https://forum.overclock3d.net/forumdisplay.php?f=32)
-   -   Post A Picture of Your Last Purchase (https://forum.overclock3d.net/showthread.php?t=51377)
g0ggles1994 18-09-21 10:38 PM
Originally Posted by Dawelio (Post 1036056)
If your signature is correct and running an 1700X, your H100 shouldn't spin up and sound like a turbine. Then something is wrong.
I have an 3700X and even during gaming, my 240 is so quiet. I can't even hear it at all, all I hear is the fans on my GPU ramping up. Never had any issues with my AIOs, other than some small pump noise.
Aye there probably is something wrong with it; it's not the first H100 I've had fail on me. Still, this unit has given me 5 years of solid service so I can't complain. I've got an NH-D15 on the way now and I've decided to go back to air cooling for the foreseeable future. Next time I will dabble with liquid cooling is when I make a custom loop; I'm done with AIO's for the time being.
KingNosser 19-09-21 04:38 AM
Same company as my last soundbar and the same price as it was 40% off so thought why not :)
https://i.imgur.com/pg4x4mO.jpg
I'm not a full on weeb but i do like me some Naruto and DBZ
https://i.imgur.com/1kvyuhU.jpg
https://i.imgur.com/r0Au7eW.jpg
AlienALX 19-09-21 11:33 PM
I have that soundbar. It still works, but the controls packed up (and the remote). Thankfully it is still loud enough to hear OK.
Bought these for my holiday.
https://i.imgur.com/u9dkXIA.jpg
And what I bought this year from spring on.
https://i.imgur.com/kZo1RjD.jpg
Did a full resto of a 1999 Morales BTS. Very rare bike.
https://i.imgur.com/0IdVfiB.jpg
Restored a 2001 2hip.
https://i.imgur.com/T2Rpkbq.jpg
Rebuilt my 01 STA with all NOS parts.
https://i.imgur.com/t17YQ6A.jpg
04 Fit Logic.
https://i.imgur.com/SpFUKCa.jpg?1
Very rare 2009 S&M Cameron Wood.
https://i.imgur.com/kU7WuS3.jpg
And a 2004 Terrible One Barcode
https://i.imgur.com/8ExtFWJ.jpg
So that's why I've not been around lol. Been knee deep in rust, paint and . The prolonged summer didn't help any.
KingNosser 23-09-21 07:38 AM
So I have tons of racing games, felt about time to get a half decent wheel and pedals set.
I did some looking I knew it'd not really be a cheap thing, but I didn't really want to spend too much, at first I was thinking about a Hori one but no force feedback and it's needed tbh so that really limited my choice, cause they get expensive!!
So there was a few options i might have waited longer for but after a fair few hours one kept popping up that was nearly as cheap as the hori but has force feedback and by all accounts is decent, least 2nd hand decent :D
So taken a punt on the logitech Driver Force GT, yep it's a bit older but it'll work on my PC and be better than the Hori i was close to deciding on, it's a starter kit tbh and that's fine but I honestly can't justify 200+ for a new bit of kit.
https://i.imgur.com/VsTh2IY.jpg
2nd hand boxed in good looking condition these days is 69 P&P included on this so I'm hoping I'll not be disapointed but i've heard decent things about this wheel so I'm hopeful :D
PS. Alien is a spider monkey and rides all the bmx's at the same time hence why he needs so many of them :P
Greenback 23-09-21 10:21 AM
It's a new experience with proper wheel when you play in VR though takes a bit to get use to I found
KingNosser 23-09-21 10:53 AM
I'll start with the normal way first have sega rally and outrun installed and ready then Dirt 2.0 ect all the normal, maybe some other arcade games before using it in VR at least get used to it first, but i've heard good things about the kit for an older wheel.
So long as it works fine and turns up in one piece i'll be happy, so a few days to wait before testing it all out in everything, but the sellers pictures were decent and show'd plenty so it seems in good condition.
Even for a slight upgrade to a G29 or 150/tmx even 2nd hand would have cost me more than double then after that brand new ones are 225+ insane how high the prices on them go tbh.
So much so you could go out and buy a decent 2nd hand car lol
I had a small thought about pedal slippage, so ordered a cheap Yoga Knee Mat it should work others seem to say it will work well small enough to go under the desk and have the pedals sit on it, i'll report back if it's a GG fix :D
Greenback 23-09-21 02:57 PM
If you have your desk against a wall you can have them against that or there's a grip o the bottom for carpets
KingNosser 23-09-21 02:59 PM
Well I have hard floors no carpet under the desk, but even against the wall it could move about so i'll give this a go plus it was only 3 so no real loss :)
Dicehunter 24-09-21 01:43 AM
1 more piece for my red, White and black themed build ^_^
https://i.imgur.com/4miKxfe.jpg
g0ggles1994 27-09-21 06:43 PM
Officially back on air cooling now. This thing is an absolute monster; silent while idle, quiet when gaming and my CPU is now topping out at 64C rather than hitting 80-90C on the H100i. Had to replace my RAM as mine was too tall and while doing so, I thought 'sod it' and upped to 32GiB and since I have a Ryzen tuned kit, I can finally hit its rated speed of 3600MHz on my 1700X.
https://i.imgur.com/euwaJ9r.jpg
