This was on a dual Xeon Photoshop rig, so you can imagine how annoying it was to lose work all of the time. The 7970 though was the worst card/driver combo I have ever had. It would take me a good twenty minutes just to list all of the issues I had with that. IIRC I had it about a month before swapping it for two brand new GTX 480s. And the 7970 for me at the time was basically two months of saving. I just did not have a spare penny to rub back then. I shouldn't have bought that card in the first place though, so it was my fault. Mind you, I did buy the card and the 3d monitor AMD recommend for using Tridef on, so it really should have been better. Since Frame Pacing + 6 months their drivers are far, far better. The 290 I had was seamless and so has the Fury X so far. |
In the end we are just trying to justify our considerable investments to each other. The support the underdog approach to choosing AMD is laudable, but it shouldn't be the singular reason. Don't fear a monopoly, there are laws to prevent such things from happening and makes the weaker companies try harder. |
Adaptive V-Sync is Freesync btw... it's just AMDs term for it. Its the Displayport standard. Quote:
I'm not trying to justify anything. I'm merely just bringing up what I see and what I know. I support AMD because I don't trust nor like the way Nvidia runs. I don't want to support that, that's my reasoning, however adding in the monopoly thing is another good reason. Yes there are laws but if they become a monopoly legally by just selling more than the next guy and the next guy ends up failing, there's not much the government can do. You can't really do much here.. no one else is in the market to even think about going against AMD or Nvidia. It's really just 2 businesses and only one is going to win. I'm here to help get the underdog some support to prevent a single winner. Quote:
At the time I bought my 7970 I had a MSI MATX X58 board and a 950, here are the issues I had. 1. Small, purple and white blocks all over my icons (Windows 7). 2. When allowing the monitor to go to sleep when awakening the PC I would lose half of my desktop. Not black, it would still be there, but anything below the center line was a black hole. So for example if I dragged a folder down there it would disappear under the desktop and I could not get back to it without rebooting the PC. 3. Artefacts and big lines and triangles in games. 4. Zerocore did not work, the card was always clocking at 1ghz. I could go on and on. I formatted and reinstalled my PC when I got the card because the install was kind of old. Edit. I know the card was not faulty because I swapped it with a guy who AFAIK is still using it now. |
Freesync and G-Sync are adaptive sync technologies. Here's some more info about Nvidias adaptive v-sync, It literally just turns v-sync on and off very quickly - http://www.geforce.co.uk/hardware/te...adaptive-vsync http://i.imgur.com/lzS5s3v.png |
