OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   Asus UK Customer Care Forums (https://forum.overclock3d.net/forumdisplay.php?f=132)
-   -   Rog Strix 850 white power supply (https://forum.overclock3d.net/showthread.php?t=96607)
skullen 03-04-21 04:26 PM
Hi,sorry if this is a bit long winded
I have the asus strix white edition 850w power supply.
cables that came with it dont fit into the 4 pin and the 8 pin ATX plugs,the pin configuration is different to the board which is also Asus ( rog strix B550- gaming ).
Any help would be much appreciated.
WYP 03-04-21 04:41 PM
Can you show us a picture of the cables that you are trying? They should fit if they are the right cables.
Practically ll DIY motherboards feature the same inputs.
skullen 03-04-21 05:32 PM
Hi WYP,hope these help.
https://i.imgur.com/0Evpu9dl.jpg
https://i.imgur.com/CDLmDFel.jpg
Even if i swap them round they still dont match up.
Thanks
Ian.
Dawelio 03-04-21 06:47 PM
That looks to be the incorrect cable, as even though you are holding them togheter incorrect (the latches should be togheter and hence not a gap between the pins), the bottom outer pins on the motherboard are squares, meanwhile your cable only has a single square on one side and a rounded one on the other.
skullen 04-04-21 01:47 PM
Thanks for the replys all sorted.
