OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   New Build Advice (https://forum.overclock3d.net/forumdisplay.php?f=28)
-   -   Best Budget Gaming Keypad (https://forum.overclock3d.net/showthread.php?t=93736)
Warchild 10-01-20 03:30 PM
Originally Posted by g0ggles1994 (Post 1014716)
Welp, in that case mate, would you be so kind to share your knowledge? :lol:
ill put pics up in the build log section. Its nothing special but I was quite proud of it :D
https://forum.overclock3d.net/showth...55#post1014755
There you go. This is how I resolved it.
g0ggles1994 15-01-20 02:51 PM
Thanks dude, great work! I've looked into something similar with mine but because of mine being a corner desk with a frame underneath, it'll be a hell of a challenge to fashion something that could fit. That being said, it did give me the idea to attach something to my chair's arm rests instead which I'm looking at now.
Back on the keypad thing, I've found someone auctioning a boxed G13 which I'm considering bidding on last minute to get it cheap
Greenback 17-01-20 09:41 AM
Not played Elite for a while, so not sure how much has changed, I used voiceAttack and HCS voice packs this can do so much and free up buttons going through menus is simple, for the galaxy map I used the "5" button as a modifier and the directional switch to move around. obviously doesn't help in typing in search box.
I have an Orbweaver I use for FFxiv and find it comfortable to use though my fingers aren't long enough to reach the furthest buttons I use them for non-important things
