OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   Off Topic Chat (https://forum.overclock3d.net/forumdisplay.php?f=32)
-   -   Post A Picture of Your Last Purchase (https://forum.overclock3d.net/showthread.php?t=51377)
Excalabur50 10-07-21 10:44 PM
Well I'm going to send my S21 Ultra back the battery tanked again over night to 3% :(
Damien c 11-07-21 08:57 AM
Sounds like it's broken.
I am charging mine every other day mostly unless for some reason I have used it quite abit in a day.
Damien c 13-07-21 02:08 PM
Got my new Logitech G915 Wireless keyboard today.
Oh wow is it thin but it has some weight to it.
Now just got to get use to using it, but so far very very happy with it.
The thin keycap's maybe annoying to some but I really like it, finding it easy to type on.
Also liking that it has Bluetooth and Wireless so I don't need to unplug the Wireless dongle each morning and plug it in to my work laptop, I can just press the Bluetooth button to switch to "Work Mode".
AlienALX 16-07-21 09:48 PM
Room makeover.
https://i.imgur.com/XzclirF.jpg
https://i.imgur.com/cjSevQ8.jpg
https://i.imgur.com/vC5BGjn.jpg
https://i.imgur.com/HPPw84u.jpg
Damien c 25-07-21 10:59 AM
Not an "Photo Taker" so excuse the photo's.
New purchase thanks to my dad needing a upgrade and him buying my "old" stuff which was only bought last year :hehe:
AMD Ryzen 9 5950x
Gigabyte X570 Auros Elite
32Gb Corsair 3600Mhz
Corsair H150i Elite Capellix
12x Deepcool CF120 Plus fan's
Corsair RMX1000 PSU
Corsair Cable Kit (Red & Black)
Corsair 5000D Airflow
https://i.imgur.com/rbE119k.jpg
https://i.imgur.com/IAgmJNp.jpg
https://i.imgur.com/J8fsnlT.jpg
https://i.imgur.com/dJ7T5Rg.jpg
The case does not make it easy to deal with cables and next month, I will more than likely be buying the 7000D Airflow, and then start prepping for a full custom loop but the AIO will do till I get everything sorted.
Warchild 25-07-21 02:10 PM
You have all fans as exhaust?
Damien c 25-07-21 02:27 PM
Crap guess I should have slept :(
I will have to swap some round but yes like an idiot they are all exhausting.
trawetSluaP 25-07-21 02:50 PM
I've just downsized to a 5000D too. Most of my rads don't fit though so gonna have to change the loop I had planned...
Damien c 25-07-21 02:58 PM
Yeah I got this because I needed a new case and it was cheap enough to fit in the budget, but the 7000D is going to be purchased as soon as I can, as the 5000D is just to small.
Damien c 25-07-21 05:54 PM
Well now have 12x Lian-Li Uni SL120 fan's on order so will see how they work out as everything I have seen about them looks really good.
I really do not recommend those Deepcool CF120 Plus fans, they are basically not moving any air, they struggle to move a single piece of A4 paper of the top of the case which has 6 fans pushing air up 3 in push and 3 in pull on the AIO.
