OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   Off Topic Chat (https://forum.overclock3d.net/forumdisplay.php?f=32)
-   -   Post A Picture of Your Last Purchase (https://forum.overclock3d.net/showthread.php?t=51377)
Cru 09-11-13 10:50 AM
http://i.imgur.com/SdV88AA.jpg
oh hello
Damien c 09-11-13 11:02 AM
Originally Posted by SeekaX (Post 698842)
it looks out of place, you know, like a case badge. ew.
I know and it does appear that it will peel off but I don't want to do it just yet as I only got them yesterday.
To be honest though it won't matter once they are under water if I do eventually put them under water.
yassarikhan786 09-11-13 11:35 AM
Originally Posted by MrKambo (Post 698674)
ive got one of them, im assuming the AC version?
also look into this http://www.lostrealm.ca/tower/node/79 ;)
Yup, it's the RT-AC66U. Set it up yesterday and I'm loving it so far. Thanks for the link :)
looz 09-11-13 11:51 AM
I'd recommend http://www.dd-wrt.com/ as a custom router firmware.
yassarikhan786 09-11-13 11:53 AM
The current one's doing fine at the moment :)
Thanks for the link though. I've saved the link and will make use of the custom firmware if I feel it necessary.
WillSK 09-11-13 12:28 PM
Noob question...
So call me stupid but what are the advantages of buying a new router as opposed to the one that comes with my sky broadband for example? Also if you get a new router/hub does it still work with whatever provider you have or would it merely be an extension of thee existing sky hub I have ?
MrKambo 09-11-13 12:40 PM
dd-wrt doesnt work on the AC version of the router as thats my go to firmware
Originally Posted by WillSK (Post 698994)
Noob question...
number of reason
  • service providers routers are poo at best
  • more powerful wi-fi
  • specfic routing options
  • VPN
  • Print Server
  • Gigabit Support via LAN
Im using sky fibre FTCC, and finding compatible routers was a pain, but the Asus coupled with Merlin firmware works AMAZING!!! wants to be for the money they charge for it, but i dont regret spending it one bit!
WillSK 09-11-13 12:43 PM
number of reason
  • VPN
  • Print Server
So with your new router you get stronger wi fi in the house? Can it ever result in faster wall speeds. I'm a homeplug user due to being the opposite corner of the house to the router. I really need to get more clued up with this kinda stuff
MrKambo 09-11-13 01:07 PM
right just to sum it up
wired will always be faster than wi-fi, i want to use home plugs but heard mixed stories about them working with extensions sockets.
my wi-fi speeds doubled when i put this router in place i also gained the 5GHz wi-fi band which is awesome as my rig and iphone run on this network and everything in my house runs on 2.4GHz
i also wanted to make sure i could stream my blurays to the mobile devices in my house ranging from droid and ios devices, so changing my router was best option. i will be moving to homeplugs for my rig as i want to game online
barnsley 09-11-13 01:11 PM
Don't use homeplugs on extension lines, depending on the model they simply either don't work or they struggle.
